Dodge Dakota power steering problem #2518417
07/06/18 02:13 PM
07/06/18 02:13 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I have a 2004 Dakota with approx. 40K miles. A few days ago I got in it to run an errand and the power steering suddenly felt much stiffer to turn than when previously driven. I checked the fluid and it isn't leaking or low and the belt turning the pump is fine. Tires all have proper inflation. Could ball joints have anything to do with this? I think I read somewhere once that Dakotas like mine were known to have premature failing of the upper ball joints. If not, what else should I look for that might be causing this to happen?
Re: Dodge Dakota power steering problem [Re: 440mopar] #2518513
07/06/18 06:26 PM
07/06/18 06:26 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Sounds like either the p/s pump is going out or the joints in the steering shaft have seized. My Durango pump went out all at once. No assist whatsoever and I could barely turn the steering wheel. I had read about the steering shaft joints getting stiff or seizing but mine had already been replaced.
Ball joints would prematurely wear out and come apart. I happened to be standing in the driveway one day when my son stopped by in his Dakota. I heard the clunk and saw the tire jerk as he turned in. Needless to say, he went home with new ball joints.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Dodge Dakota power steering problem [Re: I_bleed_MOPAR] #2518558
07/06/18 08:04 PM
07/06/18 08:04 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I just went through he exact same thing with my '04 Dakota. Mine was the two little universals in the steering shaft. I squirted oil on both universals and it cured the problem. That's where I'd check first.
Re: Dodge Dakota power steering problem [Re: GODSCOUNTRY340] #2518665
07/07/18 01:41 AM
07/07/18 01:41 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
my 03 dakota did that once on a cold winter day,it broke loose and worked ok after a minute or so,
back in the 80'sgm had problems with the seals in the rack binding up in cold weather,the fix was to hone out the rack and use new seals
my ladder of success is missing some rungs
Re: Dodge Dakota power steering problem [Re: 440mopar] #2519107
07/08/18 10:24 AM
07/08/18 10:24 AM
NJ
rth Offline
rth  Offline
NJ
Try spraying W-D 40 on steering shaft universal. Common problem, especially when not driven often.
Re: Dodge Dakota power steering problem [Re: 440mopar] #2519252
07/08/18 06:50 PM
07/08/18 06:50 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And spraying anything on the steering shaft is only a temporary fix..If they're rusty/seized enough to get tight they need replaced... twocents Last shaft I kept spraying would get loose temporarily..When I replaced it you could hold it straight out the universals were that bad they wouldn't bend anymore than they had to...
Re: Dodge Dakota power steering problem [Re: screamindriver] #2521743
07/14/18 10:34 AM
07/14/18 10:34 AM
NJ
rth Offline
rth  Offline
NJ
Yes, my mistake. I should have included this was to pinpoint problem, not a "fix".
