Re: How to cool my 505
[Re: Smoparmike]
#2518463
07/06/18 04:10 PM
07/06/18 04:10 PM
Posts: 4,457 Washington
madscientist
Washington
First things first. The water pump needs to be a high volume pump. You need a high flow thermostat. I use only Stewart thermostats.
Second is check your pulleys. The slowest the water pump should turn is 1:1 and IMO that is too slow. I'm at 6% over and I'd rather be at 10% but I couldn't find the right pulleys.
Those are the two most important things I see that you didn't answer. If you have a 26 inch two core radiator that should be plenty big.
[Re: Smoparmike]
#2518471
07/06/18 04:29 PM
07/06/18 04:29 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
not enough timing on the street will also make them run hot.
[Re: CSK]
#2518480
07/06/18 04:40 PM
07/06/18 04:40 PM
Challenger 1
Cincinnati, Ohio
not enough timing on the street will also make them run hot. And not enough fuel, running lean and mean will make them run hot. You don't want them lean and mean on the street. Richen it up, I bet it helps.
[Re: Challenger 1]
#2518488
07/06/18 04:55 PM
07/06/18 04:55 PM
Posts: 369 Bowler Wisconsin
Smoparmike
Bowler Wisconsin
This a new build. I have only driven twice. I live about 3 miles from our little town drove there and back 45mph temp just keeps climbing. Drove once with fixed blade mechanical fan no shroud and once with 16 in electric fan no shroud. Not sure if rich or lean I'm running 2 750 eldebrocks on cross ram. The water pump housing is from 440 source. Northern radiator is aluminum with 2 rows of one inch cores. I checked pulleys both are 6-1/2.
[Re: Smoparmike]
#2518504
07/06/18 05:55 PM
07/06/18 05:55 PM
Posts: 506 Utah, USA
1964superstock
Utah, USA
I have a max wedge 505 in my '64 Plymouth Savoy street car, also using an original 22 inch mopar brass/copper radiator, recored with a copper high efficiency 3 core. Using a high flow 440 source water pump (I know some don't like this pump, but works well for me), original aluminum '65 race hemi water pump housing, race hemi 7 blade aluminum fan with Hayden 2947 heavy duty clutch, and original steel shroud, all mechanical, no electric fans. I swapped from a 180 degree, to a 160 degree high flow milodon thermometer, which helps the engine stay cool, as the thermostat opens and lets the much lower temp coolant from the radiator do its job, before the engine goes in to thermal meltdown mode. In my experience, once the engine hits 180 degrees using at 180 thermostat, it is tough to get it the temps below 190 in the summer. Tip, a thin layer of Hylomar blue on the thermostat gaskets and radiator hose ends do miracles for keeping it sealed up. To aid cooling, you could increase the percentage of water in your coolant mix, such as 30% coolant/70% distilled water, or 100% water with water wetter added. I prefer using Zerex G-05 coolant 50/50 mix with distilled water for rust protection. You could also try flushing your engine cooling system with Evalorust thermocure, even though it is a new build. I would not count on all the rust being removed from the coolant passages of your vintage block. I used this, and was surprised at the amount of crap that came out, new engine build also. It did help cool it a few more degrees by removing some rust from the iron engine block. Easy to do this on a weekend. A quick experiment you could try, is run some 110 octane leaded race fuel. With no other changes, I added 110 octane leaded race fuel vs. straight 100 octane no lead race fuel, and my engine dropped immediately 15 degrees in temp. This was back to back, filling up at the pump. I usually now mix half and half 110 leaded race fuel, with 88 octane non-ethanol pump gas, which makes 99 octane leaded fuel. Saves a few bucks for gas, and I can get away with 34 degrees total timing, no detonation, and runs cooler. Your 505 will love the 110 leaded race fuel anyway, bump the total timing to 35-36 degrees and hold on! One other quick help, remove the bottom splash shield behind the front bumper and in front the bottom section of the radiator, it helps to get more air flow into the radiator from below, and will cool your engine few more degrees. Hope any of these ideas help, as they seem to work for keeping my 620 HP 505 cool in the hot Utah summers. Mine stays around 180 degrees in the hot weather, but I have to keep the car moving a decent speed. If I stop at a bunch of stoplights, the temps start climbing to 190-200. Looking to be over 100 degrees at my home today, so honestly, I don't push my luck with a 620 HP stroker big block mopar on a day like today. I try to wait to drive it until it cools down a bit in the evenings or morning, for fun blasting around. Here are some links: https://www.forbbodiesonly.com/moparforum/threads/hayden-fan-clutch-low-profile.115490/https://www.summitracing.com/parts/hda-2947https://www.summitracing.com/parts/mil-16405/overview/https://www.walmart.com/ip/Thermocure-by...9ffb0f66128fa6bhttps://www.walmart.com/ip/ZEREX-Antifreeze-Coolant-1-gal-Concentrated-ZXG051/119274583
[Re: Smoparmike]
#2518512
07/06/18 06:26 PM
07/06/18 06:26 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Most of the aftermarket housings have a huge bypass hole in them. More bypass = less water through the radiator.
I’m not going to get into a debate about it, but this is “what I would do” to help determine how much of the problem is coolant flow, how much is air flow/radiator capacity.
-get a milodon high flow water pump -find a stock iron pump housing and plug the bypass hole -run the milodon pump in the stock housing with no bypass, no heater hoses(heater hose fittings plugged, not “looped”)and no thermostat
If it still runs hot, it’s not a coolant flow problem.
FWIW, I don’t think you’ll have success until you open up the rad support and get a 26” aluminum radiator, and run with a decent fan and shroud.
[Re: Smoparmike]
#2518529
07/06/18 07:04 PM
07/06/18 07:04 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Go back to your mechanical fan but with a shroud.
JAKES AUTOMOTIVE
[Re: Smoparmike]
#2518595
07/06/18 10:05 PM
07/06/18 10:05 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My Duster is a mid 10 second street car with a mild 500" motor, high volume mechanical water pump and aluminum housing from Mancini, along with a Northern aluminum radiator. I use a black plastic flex fan, car never runs hot.
The key factor was the shroud. Without a shroud the motor would get hot, with a crappy shroud it was much better but would eventually get hot.
Now I have a custom fit aluminum shroud and I can drive it all day in the heat. The shroud is on the same angle as the fan, and the fan blades stick out of the shroud about half way.
[Re: Smoparmike]
#2518642
07/07/18 12:21 AM
07/07/18 12:21 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Unless I missed it ,what is your temperature keep climbing to? New build will run hotter till broke in. Whats your temp gauge say? Are you sure the gauge is accurate?
[Re: fast68plymouth]
#2518653
07/07/18 01:02 AM
07/07/18 01:02 AM
1964superstock
Utah, USA
FWIW, I don’t think you’ll have success until you open up the rad support and get a 26” aluminum radiator, and run with a decent fan and shroud. Dwayne, thanks for this info about plugging the water pump housing bypass hole. Easy solution, along with the Milodon high flow water pump and no thermostat to check coolant flow. No heater in my car, so don't have to worry about that.
