Can you indentify this wiring harness? #251821
03/12/09 05:05 PM
03/12/09 05:05 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
I think it is from an E-body........
Re: Can you indentify this wiring harness? [Re: BADBEE] #251822
03/12/09 05:56 PM
03/12/09 05:56 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
2-Speed Windshield Wiper Harness?
P/N 2983 117 = 70-71 A-Body and 70 B-Body 2 speed Wiper Motor Harness
Re: Can you indentify this wiring harness? [Re: Snoopy] #251823
03/12/09 09:40 PM
03/12/09 09:40 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
I can make out the last 5 digits of the part number tag,88212. There is also 96555-C on the tag.
Re: Can you identify this wiring harness? [Re: BADBEE] #251824
03/12/09 10:21 PM
03/12/09 10:21 PM
Snoopy Offline
Snoopy  Offline
It could be 3588212, but I don't show that number in my parts books. P/N 2983451 is 70-73 E-Body and 71-73 B-Body.
Re: Can you identify this wiring harness? [Re: Snoopy] #251825
03/13/09 01:47 AM
03/13/09 01:47 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
all E body and 71/74 B body 2 speed harness those are all I have for sure.
Serious doubts about another application, since erliers shares another wires with 8 terminals plug, and I think laters too. Maybe some A ? but if it does, should it be on same years
Re: Can you identify this wiring harness? [Re: BADBEE] #251826
03/13/09 01:55 AM
03/13/09 01:55 AM
Snoopy Offline
Snoopy  Offline
Can you make out any numbers before 88212? Maybe it is not a part number, but a 5 digit vendor code? The white plug looks like an E-Body wiper plug.
Re: Can you identify this wiring harness? [Re: Snoopy] #251827
03/14/09 11:44 PM
03/14/09 11:44 PM
Ozark Mo.
BADBEE Offline OP
BADBEE  Offline OP
Ozark Mo.
Yes, the white plug is what made me think it was from an E-body.
Re: Can you identify this wiring harness? [Re: BADBEE] #251828
03/15/09 12:39 AM
03/15/09 12:39 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
E AND B bodies ( 71/74 ), not just E
Re: Can you identify this wiring harness? [Re: NachoRT74] #251829
03/15/09 10:12 AM
03/15/09 10:12 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I think some of the later C-bodies used the same white plug as E-bodies
