OE 14x6 Wheel ID #2518058
07/05/18 05:45 PM
07/05/18 05:45 PM
Thigh-Gap Junction
@#$%&*! Offline OP
New user name, Same old jerk!
@#$%&*!  Offline OP
Thigh-Gap Junction
I have a set of wheels but none of my references has info on '60's wheels in that size. The pictures tell the story. What you can't see is the faint "JK" after the "14X6" stamping. The only numbers near the valve stem are a 6 on the left and a 0 on the right. The "H" has a tiny "9" between the goal posts. The "831" might be the lasts 3 digits of a part number shruggy Bolt pattern is 5 on 4.5".
Re: OE 14x6 Wheel ID [Re: @#$%&*!] #2518064
07/05/18 05:58 PM
07/05/18 05:58 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
"831" is the hoop design/configuration number
it appears there is more info stamped by the valve stem scope may require paint removal T? 6 -o- 20 shruggy
14x6.0" wheels were STANDARD for the '70/'71 model year performance badged cars - I believe that wheel design was specific to LA built Mopars
Re: OE 14x6 Wheel ID [Re: @#$%&*!] #2518180
07/05/18 10:16 PM
07/05/18 10:16 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
That is for a 1968 C-body. Since it has only the 6 0 and no dates. 1970-71 had 4 nubs for hubcaps.
Re: OE 14x6 Wheel ID [Re: NANKET] #2518264
07/06/18 01:44 AM
07/06/18 01:44 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Agreed - it's either a 68 or 9 wheel. 1970 & later did not have the bumps in-between the lug holes like this wheel. Here's a 14x5.5" 68-9 wheel from my website - look at the style of the spider (center part of the wheel): http://www.classicchambered.com/rims/14X55.jpg
Re: OE 14x6 Wheel ID [Re: @#$%&*!] #2518273
07/06/18 02:13 AM
07/06/18 02:13 AM
Thigh-Gap Junction
@#$%&*! Offline OP
@#$%&*!  Offline OP
Thigh-Gap Junction
Thanks for all the replies.
There are no other stamping marks on the wheels, and I've looked over all 4 in bright light. I did search online first and found reference to the 5.5's but not the 6" wheels.
