Re: These plugs too cold?
[Re: jbc426]
#2518431
07/06/18 02:51 PM
07/06/18 02:51 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I built the carb and he has a WB...........
[Re: jbc426]
#2518622
07/06/18 11:17 PM
07/06/18 11:17 PM
Posts: 8,038 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Yep. I have and use a wide band. Cruises 13.8 to 14.2. Im still not convinced to carb is rich. I will run some 7's in it awhile and see how they burn. I have some 6's on order as well.
[Re: mopar dave]
#2524045
07/19/18 12:44 PM
07/19/18 12:44 PM
Posts: 620 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Dave at 3K rpm cruise you should be on the mains....first Id go to NGK6 and see an, then I'd pull a little jet for better AFR, even the best carbs need dialing into your combo. Running it at cruise in the hi 14s, lo 15s aint gonna hurt it and will clean it up, there is very little load on the engine at idle or cruise. I run my Hemi in this way on NGK 6s - plugs look perfect withe a nice ring on the plg base/shell and the car runs clean/awesome. WOTs are in the mid 12s. Imho, NGK 8s are a little cold for the street generally, it really depends on your combo etc. Im gonna switch to 8s for the track. The engine is telling you what it likes...let er have what she needs
[Re: mopar dave]
#2524322
07/20/18 12:32 AM
07/20/18 12:32 AM
crabman173
crabman173
Man i run 8's in a 13.7:1 alky engine and they are almost too cold for that
[Re: mopar dave]
#2524420
07/20/18 10:24 AM
07/20/18 10:24 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Using ngk 7's now. 3000 cruise rpm afr is 13.0 now. 3500 cruise gives 12.5 range. Not sure when boosters are all in. I believe the boosters start just after 2500rpm. Plug rings have a little color, but porcilen still dark. What causes plugring to burn clean but porcilen to burn dark? Now you can at least read the plug to see what is going on with any changes.Thank you for your info.
[Re: mopar dave]
#2524631
07/20/18 05:00 PM
07/20/18 05:00 PM
Posts: 4,457 Washington
madscientist
Washington
I resently changed the t slot to a .059 from a .055. Engine sounds smoother and runs cooler. I seem to have a pump gas issue and i think it might be the ethanol boiling in the squirter circuit on a hot air temp day. Cool engine and cool air temp if goes away. I can watch the fuel spurt out of pri squirter at idle with hot engine and air temp. Switched brand of fuel and got worse. Are you saying the fuel is percolating out of the squirters or is fuel being pulled through the squirter? I remember someone on here posted a link to a company that made an anti pullover parts to stop the squirter from letting fuel get by it from airflow.
[Re: madscientist]
#2524643
07/20/18 05:19 PM
07/20/18 05:19 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
I resently changed the t slot to a .059 from a .055. Engine sounds smoother and runs cooler. I seem to have a pump gas issue and i think it might be the ethanol boiling in the squirter circuit on a hot air temp day. Cool engine and cool air temp if goes away. I can watch the fuel spurt out of pri squirter at idle with hot engine and air temp. Switched brand of fuel and got worse. Are you saying the fuel is percolating out of the squirters or is fuel being pulled through the squirter? I remember someone on here posted a link to a company that made an anti pullover parts to stop the squirter from letting fuel get by it from airflow. Another thing that I heard helps is to not use the tube style squirters.....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: mopar dave]
#2524801
07/20/18 11:44 PM
07/20/18 11:44 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
Does it have the correct check valve, anti siphoning ball, under the squirter? if not, get one first and see if that helps The first 4 barrel I "rebuilt, dipped and kitted,(1957 Chevy Rochester 4GC) ended up with me not knowing where that check ball went Stuff happens
[Re: mopar dave]
#2524809
07/20/18 11:59 PM
07/20/18 11:59 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I run NGK 8s in my small block 11 to 1 pump gas drag week motor. Usually do the week on only two sets. The street drives dirty them up a little, but the nitrous passes clean them right up!!
When I ran it NA, I had 7s in it all week, and they were perfect.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: mopar dave]
#2524967
07/21/18 01:16 PM
07/21/18 01:16 PM
Clanton
northern,Ohio,USA
Yes. It does have the check valve. I still think its the fuel. My brother inlaw has same issue with a edelbrock carb. Maybe you can find someone with a fuel gravity test kit I don't know what other things you can check.Will you try a new gas station/brand?I got some #7 plugs to use and your info was helpful in choosing the plugs.
[Re: Cab_Burge]
#2524993
07/21/18 02:23 PM
07/21/18 02:23 PM
Thumperdart
State of confusion
Does it have the correct check valve, anti siphoning ball, under the squirter? if not, get one first and see if that helps The first 4 barrel I "rebuilt, dipped and kitted,(1957 Chevy Rochester 4GC) ended up with me not knowing where that check ball went Stuff happens No ball bearings that's old skool it has weighted check valves............
[Re: Thumperdart]
#2525006
07/21/18 02:58 PM
07/21/18 02:58 PM
Cab_Burge
We have learned a lot since then, huh As far as sucking fuel out of the squirters that is usually a sign that the carb. is NOT idling on the idle circuit only, it may be idling up on the transfer slots
