I have a 5.7L stroked to a 392 with the Ritter Intake, Thitek heads, and running a carburetor on E85. I would like to install a vacuum pump to help keep the oil clean. I have a catch can connected to the drivers side of the intake, which is also where I add oil, and there seems to be quite a bit of blow-by coming from that area, so much so that I don't believe it would be a good idea to hook a vacuum pump to that port. Can anyone recommend where a good place would be? I know the valve covers are very tight for clearances. I know that some people are running the header-style evac system and are hooked up to that port but don't seem to have that problem.
Any recommendations, or am I just over-thinking this??
