OK TRANSMISSION GURUS #2517177
07/03/18 09:14 PM
07/03/18 09:14 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
I'm having my 998 in my 78 Magnum serviced, I had mentioned maybe bumping up the line pressure a "tad", since this is a stock untouched 998, (hydraulic lockup), will this interfere with the operation of the lockup, which at this point, works fine.
I figure the servicer knows if that's ok or not, but thought I'd ask just in case.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: OK TRANSMISSION GURUS [Re: Magnumguy] #2517180
07/03/18 09:20 PM
07/03/18 09:20 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
If you do make sure you turn it the correct direction, counter clockwise raises pressure.
Re: OK TRANSMISSION GURUS [Re: Magnumguy] #2517502
07/04/18 02:58 PM
07/04/18 02:58 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No it wont hurt it moving the line pressure up a small amount. I worked for a Dodge dealer for 24 years and did auto trans work. I usually always raised the line pressure a tad on stock overhauls. Ron
