How much stroke with stock “971” oil pan for 73 charger? #2516698
07/03/18 12:19 AM
07/03/18 12:19 AM
New York, USA
Chargerfan68 Offline OP
New York, USA
Im looking to build a pump gas stroker for my 73 charger and need to know if the 4.25” stroke will clear the factory 971 pan for the charger on 73/74 years. I dont want a deep sump pan for this car, as its a daily driver. Im not against a different pan that will clear the k member as long as it doesnt hang lower than the frame. What do you guys do?
Re: How much stroke with stock “971” oil pan for 73 charger? [Re: Chargerfan68] #2516986
07/03/18 03:42 PM
07/03/18 03:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
4.25 with a 2.200 journal fits that pan.
Re: How much stroke with stock “971” oil pan for 73 charger? [Re: Chargerfan68] #2517264
07/04/18 01:16 AM
07/04/18 01:16 AM
New York, USA
New York, USA
Thanks for confirming that, Dwane. The only thing i could dig up on the net were dimensional drawings which indicate that a 4.25 would work, but i want to make sire before pulling the trigger on the rotating assy. I am actually going to call you for a camshaft/ lifters for this engine. I was thinking about a hyd roller for this but wanted yo talk to you about the durability of the lifters for street. This will be a 95% street car with 10.4 comp , stealth heads (std port opening) , headers, thinking about indy dual plane, i have an hp 950, 727, and 3.23. (I do have 3.91 i could swap to). HEAVY b body. 4165 with me in seat. If vacuum is a problem, i will solve it by ripping power bouster off and swap msnual disc master on car:). Im perfectly happy with manual disc.
