How do racers like Tru Start
#2516522
07/02/18 06:35 PM
07/02/18 06:35 PM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
One vote here..... i love it. Our local track doesnt use it. Like that Norwalk does. Less gift wins for big wallet cars
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: How do racers like Tru Start
[Re: B3422W5]
#2516526
07/02/18 06:48 PM
07/02/18 06:48 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Never have raced where they had it, but I like the idea of it.
If I had the choice, I’d prefer it be used.
[Re: justinp61]
#2516531
07/02/18 07:06 PM
07/02/18 07:06 PM
B3422W5
Portage,michigan
Okay.........what's Tru Start? Even in a handicapped bracket race if the slower car goes red, he can still win if the faster car goes red worse. So if both go red, the lesser red wins. Usually slow car goes red its over, no matter what faster car does
[Re: B3422W5]
#2516535
07/02/18 07:10 PM
07/02/18 07:10 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
I have never done it, but I vote yes
[Re: CSK]
#2516537
07/02/18 07:13 PM
07/02/18 07:13 PM
Posts: 20,178 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Quick breakdown.
Slow cars love it
Fast cars hate it
And middle running cars are 50-50
[Re: pittsburghracer]
#2516538
07/02/18 07:17 PM
07/02/18 07:17 PM
B3422W5
Portage,michigan
Quick breakdown.
Slow cars love it
Fast cars hate it
And middle running cars are 50-50 Perfect.
[Re: B3422W5]
#2516563
07/02/18 08:11 PM
07/02/18 08:11 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Okay.........what's Tru Start? Even in a handicapped bracket race if the slower car goes red, he can still win if the faster car goes red worse. So if both go red, the lesser red wins. Usually slow car goes red its over, no matter what faster car does Ahhh........I see said the blind man.
[Re: dvw]
#2516566
07/02/18 08:21 PM
07/02/18 08:21 PM
Posts: 1,101 Massillon, Ohio
cudatom
Massillon, Ohio
If you want to get the benefit if you red light, build a quicker car. That's one of the few benefits you get for spending thousands to go quicker. Just my 2 cents Doug Doug I agree completely.
Ok
[Re: cudatom]
#2516597
07/02/18 09:27 PM
07/02/18 09:27 PM
Posts: 2,046 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
It's different, for sure. It is used at Bristol in the bracket racing series. Just last week I had to spot a car a little over 7 seconds (sportsman, 1/4 mile), I bumped in at my leave RPM's, then dropped to an idle, leaned over and watched her leave. Looked like she drilled me, her green light on. I go back to my side of tree (7 sec spot, I got plenty of time!), bring the RPM's back up, and hammered the tree, .013, then, as I go by the tree, her red light popped on (she is -.024). Caught me by surprise, I had to look again, then I saw my win light on. It does take some getting used to. There was also a run later on in the class where both drivers recorded -.001. I believe that the clocks count more decimals than the printer prints. I have one of the faster cars in the class (10.60's, quickest car usually 9.90's with a couple of 10.30's/10.20's in between us), but it really doesn't matter to me one way or the other. I try to run my own race. I'm just happy to have a nice place to race 1/4 mile!
Brian
edit: In the picture, you can see her green light on, but it popped red just as I cleared the beams.
[Re: gofish]
#2516684
07/02/18 11:52 PM
07/02/18 11:52 PM
B3422W5
Portage,michigan
As far as I see it, this actually does make the worst the loser. If both redlight, the worst should be the loser, after all, it is the same infraction. Worst should apply when one commits a worse infraction than the other.
Danny Exact same take i have regards it.
[Re: B3422W5]
#2516689
07/02/18 11:59 PM
07/02/18 11:59 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Who comes up with these new rules ? The STREET OUT LAW bunch? Whats the point? to see if the faster car red lights? It's always been ,first or worst, but never heard of a worst red light loosing.
[Re: Cab_Burge]
#2516704
07/03/18 12:27 AM
07/03/18 12:27 AM
Posts: 1,111 Usa
A39Coronet
Usa
To win in bracket or any type of break out racing you need to drive the starting and finish line better than the other driver
This statement seems to contradict the earlier portion of your post. If I'm leaving first, kick it .001 red...but you leave second but go .010 red...who drove the starting line better? Numbers say my 001 is closer than your 010. Given TruStart shows my lane as green initially, my red didn't influence your RT.
