Re: Race car brakes, where did I go wrong?
[Re: The Sphinx]
#2515970
07/01/18 06:05 PM
07/01/18 06:05 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Get yourself a gauge and start checking pressures.
[Re: fast68plymouth]
#2515977
07/01/18 06:18 PM
07/01/18 06:18 PM
Posts: 4,457 Washington
madscientist
Washington
Get yourself a gauge and start checking pressures. This^^^^^^^^^^^^ Until you know how much line pressure you have you are just guessing. My WAG is you cobbled a bunch of crap together and you can't generate enough line pressure to make it stop.
[Re: The Sphinx]
#2515979
07/01/18 06:20 PM
07/01/18 06:20 PM
RapidRobert
some random thoughts, you might get it up on stands & see if you can bearhug & turn each whell forward while a helper holds the pedal. You get some parts house 3/16 inverted flare fittings/short prefabbed 3/16 brake line & bypass the prop valve. You can cap the MC ports & the pedal should be rock hard with virtually no travel (try easy pedal & try stomping on it) then hookup the fronts & see if the front wheels are bearhug tight. Holler how it goes
[Re: The Sphinx]
#2515995
07/01/18 07:01 PM
07/01/18 07:01 PM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
If you have access to a pressure bleeder you might give that a try. I just changed masters and added rear discs and I was unable to get the rears to work until my dad brought over his pressure bleeder. I could get fluid at the rear but no pressure and no pedal. A few minutes with the pressure bleeder and all was well. There was lots of air in the rear lines even though what little fluid i was getting appeared fine.
68 Barracuda Formula S 340
[Re: The Sphinx]
#2516012
07/01/18 07:43 PM
07/01/18 07:43 PM
Posts: 11,557 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
To even have a chance of figuring anything out, you need to know bore sizes of the MC and calipers.
[Re: The Sphinx]
#2516034
07/01/18 08:14 PM
07/01/18 08:14 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Im not familiar with the speedway brackets. Are they bolt on or weld on? I had a guy bring a car to me with the same symptoms. He bought and installed weld on brackets on the rear axle. They were not square to the rotors. All I did was cut them off, had the boy apply the brakes, and welded them on correctly. No bleeding, great pedal. Before doing any of this, I had the wheels off with the rotors bolted in place. Watched each wheel as he applied the brakes. You could see the calipers on both rears move at angles.
[Re: TRENDZ]
#2516044
07/01/18 08:35 PM
07/01/18 08:35 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
Im not familiar with the speedway brackets. Are they bolt on or weld on? I had a guy bring a car to me with the same symptoms. He bought and installed weld on brackets on the rear axle. They were not square to the rotors. All I did was cut them off, had the boy apply the brakes, and welded them on correctly. No bleeding, great pedal. Before doing any of this, I had the wheels off with the rotors bolted in place. Watched each wheel as he applied the brakes. You could see the calipers on both rears move at angles. I have seen people weld these brackets on without positioning the caliper with air before they tack it on. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Bad340fish]
#2516058
07/01/18 09:19 PM
07/01/18 09:19 PM
Posts: 8,257 fredericksburg,va
cudaman1969
fredericksburg,va
If you have access to a pressure bleeder you might give that a try. I just changed masters and added rear discs and I was unable to get the rears to work until my dad brought over his pressure bleeder. I could get fluid at the rear but no pressure and no pedal. A few minutes with the pressure bleeder and all was well. There was lots of air in the rear lines even though what little fluid i was getting appeared fine. I go along with this answer, mushy means air.
[Re: The Sphinx]
#2516196
07/02/18 01:04 AM
07/02/18 01:04 AM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
too small a master cylinder bore will give a soft low pedal .But will pull up fine as long as its not on the floor . I think Mark Williams has a calculator to work this out
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
