small block valve cover gasket question
#251581
03/12/09 11:12 AM
03/12/09 11:12 AM
What kind of material was used on the small block valve cover gaskets? I am working on a 70 chally convert and the fel pro engine rebuild gasket kit that I got has what seems to be rubber valve cover gaskets. I would like to use whatever the factory used since it is going to be a factory appearing car. My initial thought was that they were cork originally? Am I wrong in my thought? Also, the tabs that stuck through were probably engine color as I would have to assume that they were on the engine prior to it being painted.
Thanks,
Brian
Re: small block valve cover gasket question
[Re: ademon]
#251586
03/13/09 03:00 AM
03/13/09 03:00 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
i use the rubber ones but i have some M/T's covers on mine and you can crank them down very tight without worrying about warping the V/C's.
Try that with stock stamped steel valve covers and you'll get the results I described.
[Re: ScottSmith_Harms]
#251587
03/13/09 08:44 AM
03/13/09 08:44 AM
Posts: 15,491 the boonies
aarcuda
the boonies
very true.
I run the MTs also wiit hthe rubber gasket. i run the rubber cause i have a solid cam and the rubber is better for removing VCs for lash adjustment. the corks gets hard and breaks after a short while.
#251588
03/13/09 10:33 AM
03/13/09 10:33 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Scott,have you ever tried this?A friend that has done nothing but bulid Mopar engines for the last 40yrs put me on to it.Use it for everything,and I mean everything.It not as slippy as most silicone's and it doesn't leak.It is aroung $6.00 a tube depending on your dealer,PT.# 82300234
