Re: E body brake cable question
[Re: burdar]
#251570
03/12/09 11:57 AM
03/12/09 11:57 AM
Posts: 396 BC
70RT27N
BC
On my car, the right side e-brake cable DOES NOT cross over to the drivers side. It goes into a clip that is welded to the inside of the passengers side frame. So in that instance, there is no "intermediate cable" correct. There is just a long braded metal line connecting the front and rear cables?
What year is your car? I believe 71 and newer cars used the system shown in this picture. This is a 71 Cuda...The other pictures were 70 Challengers...
[Re: 70RT27N]
#251571
03/12/09 11:58 AM
03/12/09 11:58 AM
Posts: 1,567 Ky
jt4406
Ky
I think the pics show a 70 style rear brake cable set up where the passenger side cable is longer and crosses over top the diff to the driver side and attaches like the first pic shows. I believe he has a 73 model that uses the two short cables attached to the inside of both frame rails. How do these two short cables connect to the single cable that comes rearward through the torsion bar crossmember? I think that is what he needs the pic of. jt
Yeah, it's hopped up to over 160...
[Re: jt4406]
#251572
03/12/09 11:59 AM
03/12/09 11:59 AM
Posts: 1,567 Ky
jt4406
Ky
Wow, that was fast, right pic posted before I could type my last reply. jt
