Hughes Whiplash Cam in a Low Compession 440 #2515606
06/30/18 10:27 PM
06/30/18 10:27 PM
St.Clairsville Ohio
EV2RUNNER Offline OP
St.Clairsville Ohio
Anybody running a Hughes Whiplash Cam in a smogger 440? How do you like it?
Re: Hughes Whiplash Cam in a Low Compession 440 [Re: EV2RUNNER] #2515756
07/01/18 09:22 AM
07/01/18 09:22 AM
St.Clairsville Ohio
St.Clairsville Ohio
Nobody's running one??
MOPARTY!!!
'71 RR 383 car..
'79 ASPEN R/T E58 car..
Re: Hughes Whiplash Cam in a Low Compession 440 [Re: EV2RUNNER] #2515821
07/01/18 01:01 PM
07/01/18 01:01 PM
Central NC
gch Offline
gch  Offline
Central NC
Look on youtube.I seem to remember some idle videos and burnout videos years ago.It may take more than 12 hours for most to see the post.
Re: Hughes Whiplash Cam in a Low Compession 440 [Re: EV2RUNNER] #2515834
07/01/18 01:29 PM
07/01/18 01:29 PM
St.Clairsville Ohio
St.Clairsville Ohio
Yea I've seen the stuff on YouTube, was just hoping to talk to someone that had first hand experience with one..
MOPARTY!!!
'71 RR 383 car..
Re: Hughes Whiplash Cam in a Low Compession 440 [Re: EV2RUNNER] #2515842
07/01/18 01:42 PM
07/01/18 01:42 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
I have one in a fresh 440 in my '64 Polara. Not quite to the point of first start yet but will come sometime in the next couple weeks. Will report then.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Hughes Whiplash Cam in a Low Compession 440 [Re: EV2RUNNER] #2515864
07/01/18 02:11 PM
07/01/18 02:11 PM
St.Clairsville Ohio
St.Clairsville Ohio
Cool Thanks
MOPARTY!!!
'71 RR 383 car..
Re: Hughes Whiplash Cam in a Low Compession 440 [Re: EV2RUNNER] #2522096
07/15/18 12:51 PM
07/15/18 12:51 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
The 440 in my Polara is now running. Had a great first start with 80 psi oil pressure and broke in the cam. Basic timing is set but will need to dial in the distributor advance and do some carb tuning. That said, so far I really like it. Video below is with 14* initial timing and about 28* at 2000 rpm. Stock manifolds, 2 1/2" exhaust and Cherry bomb turbo mufflers.
[video:youtube]https://youtu.be/Bc3nYutNuU0[/video]
Centerline
Re: Hughes Whiplash Cam in a Low Compession 440 [Re: Centerline] #2522776
07/16/18 08:40 PM
07/16/18 08:40 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Scratchinfortraction has one.
Re: Hughes Whiplash Cam in a Low Compession 440 [Re: EV2RUNNER] #2522987
07/17/18 10:27 AM
07/17/18 10:27 AM
scratchnfotraction Offline
yep bone stock 78 MH 440 in my 88 d100. I love mine on the street.
I ended up with the dist mech advance locked out on 0* and set at 36* with 10" vac in N and about 7-8 inches in drive. idles 750 rpm in gear 900 in N
run a 750cfm edelbrock
2nd lightest pop up spring
prim jet/rod stock
2ndary jet swap to .113 4 stage rich
holley street dominator intake
hedman 79250 headers/3" pipes/muffs dump in front of axle
stock 727 low stall TC
A-body 8 3/4 3.23sg 29x15x15 M/Ts
also run the 5.2 magnum whiplash roller cam in my pre-mag roller cam 318 and building a 360 headed 318 with the 5.9 whiplash roller cam.
did I mention I like the whiplash cams ? best bang for the buck with a lopo daily driver mopar.
