yep bone stock 78 MH 440 in my 88 d100. I love mine on the street.
I ended up with the dist mech advance locked out on 0* and set at 36* with 10" vac in N and about 7-8 inches in drive. idles 750 rpm in gear 900 in N
run a 750cfm edelbrock
2nd lightest pop up spring
prim jet/rod stock
2ndary jet swap to .113 4 stage rich
holley street dominator intake
hedman 79250 headers/3" pipes/muffs dump in front of axle
stock 727 low stall TC
A-body 8 3/4 3.23sg 29x15x15 M/Ts
also run the 5.2 magnum whiplash roller cam in my pre-mag roller cam 318 and building a 360 headed 318 with the 5.9 whiplash roller cam.
did I mention I like the whiplash cams ? best bang for the buck with a lopo daily driver mopar.
