Re: Real world weight loss program and it` cost..........
[Re: FastmOp]
#2517168
07/03/18 08:36 PM
07/03/18 08:36 PM
Posts: 1,453 N.W. INDIANA
moparjohn
N.W. INDIANA
As a followup to my Milidon aluminum oil pump here is some more weight loss! I called the tech guy at Milidon before I ordered my pump cover. I asked if I could plug that external fitting and run my internal pickup. His answer was yes I could. So after I got my cover I ordered the proper plug and got rid of another .6 ounce for a new total of 2LBS 10.8 OUNCES for this upgrade! The black cap also makes the pump less noticeable! MJ
[Re: moparjohn]
#2517355
07/04/18 11:02 AM
07/04/18 11:02 AM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Thanks!Does any one make a lighter than stock manual steering gearbox? Unfortunately, no. The only A.M. box I know of is made by Flaming River and it's cast iron. Not sure how you would go about lightening a factory steering box. Perhaps a cromoly steering shaft would be a better place to shave weight. I posted these a while back but while we're on the subject... This was Silvaliant from a few years ago, not my car.
'71 Duster '72 Challenger '17 Ram 1500
[Re: hemi-itis]
#2517470
07/04/18 02:11 PM
07/04/18 02:11 PM
Posts: 598 NC, USA
davenc
NC, USA
My 63 has the original aluminum box. There are cast aluminum manual steering boxes on E-bag. I am guessing they would be lighter than a factory manual steering box. I don't know anything about them (quality, source of casting, etc.), but have wondered about them.
[Re: Thumperdart]
#2517601
07/04/18 06:16 PM
07/04/18 06:16 PM
Posts: 200 Colorado
Bob J
Colorado
I could see that removed 50 to 60 lbs. To bad that I need to run power steering for Autocross. I will look at lighter options once the car is running. I comes down to where do you spend your money. Light is nice but running is better.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: Thumperdart]
#2517607
07/04/18 06:36 PM
07/04/18 06:36 PM
Posts: 200 Colorado
Bob J
Colorado
There is a lighter option but the wallet says do you want to loss weight or get it running.
[Re: Thumperdart]
#2517618
07/04/18 06:52 PM
07/04/18 06:52 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
Many later model cars have small pumps with remote reservoirs that can be adapted. Buddy of mine used a dirt track car pump on his big block B body conversion. Lighter and more compact that a stock pump.
[Re: Thumperdart]
#2517637
07/04/18 07:19 PM
07/04/18 07:19 PM
Posts: 200 Colorado
Bob J
Colorado
I'm running a 68 GTX convertible Wilwood brake front and back and Hotchkis suspension. Holley HP EFI Port injection coil near plug crank trigger and cam sensor yep no dist. Elederbrock XT Proflow intake and 95 mm throttle body. I was looking at a JZ jeep pump but I will look at circle tracks pumps as I didn't think of that
[Re: Thumperdart]
#2529079
07/30/18 03:16 PM
07/30/18 03:16 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
FMJ how visible is your oil pump in your car? I know you're asking about the A-990 pump but if it isn't sticking out like a sore thumb why not just patina the Milodon.... is anyone looking that hard at your stuff? Or are you just interested in it because its stock?
eBay-cdwmotorsports
