Re: Carb for Street use
[Re: DusterKid]
#2514952
06/29/18 03:35 PM
06/29/18 03:35 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I guess I look at it differently....... I feel if the car was more street friendly and more enjoyable to drive...... there’s a better chance you’ll actually drive it.
I’m probably just getting old, but trying to run a 10:1 360 and that 533 cam with closed exhaust on the street doesn’t sound like something I’d enjoy at all.
[Re: DusterKid]
#2514961
06/29/18 04:10 PM
06/29/18 04:10 PM
Posts: 3,916 usa
lewtot184
usa
a friend that lives down the street from me has a 500cuin Oldsmobile; for real bad ass! the engine has a hydraulic roller with 100 degrees of overlap on the seat. I helped him get a street tune for this beast. when I started with it the engine would only pull 1"hg vacuum in gear (10.5:1 comp, locked out msd distributor/start retard, a lot of good stuff), about 3-4"hg in neutral at 1150rpm. the "dyno tune" may have been ok on the dyno but was useless on a driver. nevertheless, after a bunch of carb change stuff and ignition timing events we ended up with about 3-4"hg in gear (2.5 power valves neeeded) and 6-8"hg in neutral. now this is with 500 cubes, so how is 360 cubes going to handle 104 degrees of overlap, and 320 degrees of seat timing?
mopar doesn't design aftermarket cams. they just put a part number on somebody else's stuff. I believe the .533 cam is either a #5196 or #5197 comp cams lobe race hydraulic. comp states "the larger lobes (268-270-276@.050") were designed with large cubic inch motors in mind in a high rpm environment".
[Re: fast68plymouth]
#2514967
06/29/18 04:19 PM
06/29/18 04:19 PM
Posts: 3,916 usa
lewtot184
usa
I’m probably just getting old, but trying to run a 10:1 360 and that 533 cam with closed exhaust on the street doesn’t sound like something I’d enjoy at all. I say it won't work.
[Re: Supercuda]
#2514982
06/29/18 04:44 PM
06/29/18 04:44 PM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
A half truth is a whole lie. Pot, meet kettle While much of what you say about the TQ is true there is a lot of what you say about the "Carterbrocks" that isn't. http://www.edelbrock.com/automotive/mc/carburetors/avs2.shtml"The AVS2 Series is the next generation in Edelbrock carburetors. The AVS2 features annular flow primary boosters with a new calibration for improved off idle and cruising performance." Seems your info is 50 years out of date. So, Edelbrock has finally brought 2 carbs to market with a single improvement to their otherwise outdated design. A 500 and a 650 with annular boosters. Hardly qualifies as 'much of what I said about them was not true'. And, does that mean the addition of annular boosters on those models is enough of an improvement to obsolete the other current CarterBrocks for most street applications like the OP's? Annular boosters are often a good thing for street applications. But that still doesn't put these little Edelbrocks on the same level as some of their competitors. Besides, wouldn't most here recommend a 750 for the OPs application? If so, then the OP would have to settle for a non-annular design of CarterBrock. And I hope that the OP's application still matters to this discussion. For the umpteenth time, it's not that the CarterBrock design is bad, it's just that there are better designed carburetors out there right now.
Master, again and still
[Re: DaveRS23]
#2515304
06/30/18 02:59 PM
06/30/18 02:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Most here would recommend that 750 be a double pumper as well. Neither of which I would recommend. Having run a 600 and a 750 on the exact same 360 in daily driver use the 750 allowed me to go past 125 mph, whereas the 600 limited me to about 118. On a daily driver this is irrelevant. The 750 also got worse mileage by about 4 mpg, on a daily driver this is significant. Seat of the pants get up and go was essentially the same. If I cared what most people did I'd drive a camaro
[Re: DusterKid]
#2516557
07/02/18 07:58 PM
07/02/18 07:58 PM
fast68plymouth
So. Burlington, Vt.
With a(what I would consider to be a more)correct cam for the application, I’d use a Holley 650DP.
[Re: DaveRS23]
#2516896
07/03/18 02:49 PM
07/03/18 02:49 PM
Posts: 792 Earth
Rob C
Earth
I am always amazed at how many people hate Carter or Edelbrocks. I don't prefer them but I have always like them when I have run them. I had duel 750's on my old street +.030 426 Hemi reworked, played with jetss, metering rods, etc until I got it the way I liked it. Everyone told me it was way too much carbs for the street. Once dialed in this car rocked & everyone who rode in it was always impressed. i agree. the holley bias is silly. the thermoquads in those '71 340's were killer. edelbrock screws up their big carbs with silly calibrations, but it's easy to fix. I like afb's and avs's. There don't seem to be any CarterBrock haters on here. It's just that there are better carbs available. Ones that have features that the AFB and AVS carbs simply don't have. The AFBs and AVSs are good carbs. But Ma Mopar abandoned them for the TermoQuad design 45 years ago. And for good reason. Abandoned? Whew! Strong wording IMO I believe not true. FWIW, the TQ was born a racing carb and it made its way into the daily drivers. The advantage of the spreadbore carb of being a flexible for mileage and power were immediately seen and taken advantage of. GM has had the Quadrajet on there cars since when.... before Chrysler did. Seems more like catch up to me.
[Re: Rob C]
#2517201
07/03/18 10:26 PM
07/03/18 10:26 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I am always amazed at how many people hate Carter or Edelbrocks. I don't prefer them but I have always like them when I have run them. I had duel 750's on my old street +.030 426 Hemi reworked, played with jetss, metering rods, etc until I got it the way I liked it. Everyone told me it was way too much carbs for the street. Once dialed in this car rocked & everyone who rode in it was always impressed. i agree. the holley bias is silly. the thermoquads in those '71 340's were killer. edelbrock screws up their big carbs with silly calibrations, but it's easy to fix. I like afb's and avs's. There don't seem to be any CarterBrock haters on here. It's just that there are better carbs available. Ones that have features that the AFB and AVS carbs simply don't have. The AFBs and AVSs are good carbs. But Ma Mopar abandoned them for the TermoQuad design 45 years ago. And for good reason. Abandoned? Whew! Strong wording IMO I believe not true. FWIW, the TQ was born a racing carb and it made its way into the daily drivers. The advantage of the spreadbore carb of being a flexible for mileage and power were immediately seen and taken advantage of. GM has had the Quadrajet on there cars since when.... before Chrysler did. Seems more like catch up to me. Abandon, replace, displace, supplant, supersede, catch-up..........whatever. We both agree that Mopar stopped using the AVS platform in favor of the ThermoQuad because of the TQ's obvious advantages. If you prefer to say that Mopar was playing catch-up with GM rather than saying that Mopar abandoned the AVS in favor of the TQ....well then fine. It's all just semantics.
[Re: DaveRS23]
#2517864
07/05/18 10:43 AM
07/05/18 10:43 AM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
So, Edelbrock has finally brought 2 carbs to market with a single improvement to their otherwise outdated design. I got a good chuckle out of this. Isn't ANY carburetor an outdated design?
No longer taking $h!t from anyone!
[Re: DUFFMAN]
#2517880
07/05/18 11:44 AM
07/05/18 11:44 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
So, Edelbrock has finally brought 2 carbs to market with a single improvement to their otherwise outdated design. I got a good chuckle out of this. Isn't ANY carburetor an outdated design? Just like the engine and car that it is attached to? And aren't the vast majority of self-tuning EFI systems throttle body? Another outdated design. Many, many things we use every day are based on outdated designs. But it would not be practical (and might even be impossible) to avoid using anything with an outdated design in our daily life. But it would seem prudent to avoid the most outdated of the outdated designs available to us.
[Re: DaveRS23]
#2517883
07/05/18 12:02 PM
07/05/18 12:02 PM
Posts: 4,678 Wichita
GY3
Wichita
I run an 850 Demon on my 505.
It starts instantly, gets good mileage and performs well at the strip.
[Re: DaveRS23]
#2517901
07/05/18 12:49 PM
07/05/18 12:49 PM
DUFFMAN
Slantytown
So, Edelbrock has finally brought 2 carbs to market with a single improvement to their otherwise outdated design. I got a good chuckle out of this. Isn't ANY carburetor an outdated design? Just like the engine and car that it is attached to? And aren't the vast majority of self-tuning EFI systems throttle body? Another outdated design. Many, many things we use every day are based on outdated designs. But it would not be practical (and might even be impossible) to avoid using anything with an outdated design in our daily life. But it would seem prudent to avoid the most outdated of the outdated designs available to us. By the time a brand new car makes it to the showroom floor chances are the tech in it is likely outdated already. But yes, you want to use the best tech feasible from a cost vs benefit stand point. That said, just because the TQ came after the AFB and AVS doesn't mean it's better. An example would be lean burn and the EFI used in the (1981?) Imperial both are arguably a step back from thir technological predecessors. As a fan of Carter carbs that is currently running a TQ I'll throw in my $0.02. I'm in the process of swapping out my 1972 340 TQ (6139s) for an Edlebrock 1406 for a few reasons; 1. I'm having difficulty with start up and I'm hoping the electronic choke (better tech than the TQ) will resolve the issue. 2. It's on a mildly warmed up 318ci with a 340 cam, J heads and 9:1 compression. TQ tuning parts (rods, jets and springs) are more difficult to find and much more expensive when you do find them, while there are a ton of sources for Edlebrock strip kits. I actually bought mine off the shelf at a local parts store. 3. Eventually I want to upgrade to a Holley Sniper which requires a square bore intake. So really the Edlebrock, which I already have, will be temporary for the intake swap. In the end the whole set-up belongs on a factory 340 car anyway. The coolness of a 340 clone under my hood has worn off and I'd rather have the better drive-ability of an EFI system.
