Flat towing a Jeep Grand Cherokee
#2513886
06/27/18 01:36 PM
06/27/18 01:36 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
I want to flat tow a 2015 Jeep Grand Cherokee behind my motorhome. Not going to use a dolly. This is going to be a 4 wheels down toad. It is towable with the transfer case in neutral. Does not need any fuses pulled like most other modern vehicles. Any body have any suggestions pro or con on towbars, baseplates, brake units, wiring taillights?
Martin
Re: Flat towing a Jeep Grand Cherokee
[Re: GomangoCuda]
#2515151
06/30/18 12:39 AM
06/30/18 12:39 AM
Posts: 259 n.c.
geo.
n.c.
Check local laws, brakes may be required. I've had very good luck with the magnetic tow light kits, sometimes under $20 at hf. The cheap tow bars work well, but are harder to hook up by yourself, well under $100. Base plate will probably be the most expensive part. If you see what it attaches to, you may be able to fabricate your own. I've towed my brothers miata a bunch, the base plate for that was $120. Good luck with this, some people have so much tied up in brake controls, transmission pumps,base plates, tow bars and auxiliary lights that I'm sure you could buy a nice open trailer.
[Re: GomangoCuda]
#2515236
06/30/18 11:41 AM
06/30/18 11:41 AM
Challenger 1
Cincinnati, Ohio
Martin I believe since you have a transfer case with a neutral that you can flat tow it. I get Motorhome magazine and every year they have Dingy towing issue with all the latest equipment and list of towable dingys. Look it up, here is a link. LINK
[Re: GomangoCuda]
#2515237
06/30/18 11:46 AM
06/30/18 11:46 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I don't know what all is needed to do it but I have a customer that flat tows a 2016 Grand.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2515259
06/30/18 12:51 PM
06/30/18 12:51 PM
Posts: 8,677 Buford, GA
I_bleed_MOPAR
Buford, GA
No help on towing other than to consult your owners manual (sounds like you have already). One piece of advice if you go with magnetic tow lights (easiest if your motorhome is wired for a trailer). Place a thin rag on the Jeep before attaching the lights. Keeps it from scratching the paint. Paper will work also till it gets wet. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: Bens_Coronets]
#2517440
07/04/18 01:22 PM
07/04/18 01:22 PM
GomangoCuda
There is a harness available to fix your parents steering problem. The Grand Cherokee did not get this type of steering until 2016. They don't have a fix yet for 2016+ G.C. That's the reason I bought a 2015.
It does not have auto parking brake or locking steering column.
Still undecided about the brake unit and lights. Too many choices lol.
