FIXED!-340 w 750 vacuum Holley dies In gear #2515066
06/29/18 09:02 PM
06/29/18 09:02 PM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
This car sat for a long time and I got rid of bad gas.
Carb needed accel pump diaphragm.
Checked power valve and replaced with 5.5.
Can hear PB booster push air when inside of car when hit brakes.
I have plugged out vacuum gage at back of carb to eliminate.
Decent built 340 with aggressive hydraulic cam and auto, Feels like 10” body on converter.
r I fixed the blown manifold.
Pulls about 7 vacuum idling. Have had it up to 10.
Idle mixtures screws respond lazy.
Not loading up and distributor reworked, advances etc.
Timing at 15 and 36 total.
Thinking of swapping out another known good carb.
What are you thinking?
Bad metering block gasket?
Blown PV again?
No leaks at manifold or base plate.
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: 340 w 750 vacuum Holley dies In gear [Re: 440PURSUIT] #2515071
06/29/18 09:06 PM
06/29/18 09:06 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Needs 4 corner idle.
Re: 340 w 750 vacuum Holley dies In gear [Re: 440PURSUIT] #2515078
06/29/18 09:28 PM
06/29/18 09:28 PM
DC, MD Suburbs
DC, MD Suburbs
Torker 2 intake
Re: 340 w 750 vacuum Holley dies In gear [Re: 440PURSUIT] #2515100
06/29/18 10:27 PM
06/29/18 10:27 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Bump the distributor to 18° and see what it does for vacuum.
Boffin Emeritus
Re: 340 w 750 vacuum Holley dies In gear [Re: polyspheric] #2515149
06/30/18 12:32 AM
06/30/18 12:32 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree Try 18* or more initial and see how it likes it.
Master, again and still
Re: 340 w 750 vacuum Holley dies In gear [Re: 440PURSUIT] #2515164
06/30/18 01:09 AM
06/30/18 01:09 AM
DC, MD Suburbs
DC, MD Suburbs
I changed to 750dp 4 corner. I put in 2.5 new power valves to make sure they help off.
Getting about 12 lb vacuum.
I have tried N-D-N with and without vacuum advance and same thing is happening.
it likes more timing and runs smooth at idle.....and idles in gear now but big RPM drop.
Then when back in Neutral it stayed at low idle kind of coughing and choppy. a little rev and smooth again....like stuck distributor weights
I will watch timing in morning dutring N-D-N.
I suspect weights are sticking and will have to change distributors.
I cleaned this one down to the weights, but the were rusty and the plate was dry.
I lubed the bushings and greased the weights.
Weights open on a drill and closed fine too.
There is 1 light and 1 medium spring.
I changed the reluctor plate to a new unit too today.
Re: 340 w 750 vacuum Holley dies In gear [Re: 440PURSUIT] #2515211
06/30/18 09:16 AM
06/30/18 09:16 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Did it run right before it was parked for a long time?
Sounds like a case of big cam and to tight converter to me.
Re: 340 w 750 vacuum Holley dies In gear [Re: 440PURSUIT] #2515214
06/30/18 10:12 AM
06/30/18 10:12 AM
DC, MD Suburbs
DC, MD Suburbs
Seemed to Idle fine when first resuscitated.
Car had an MSD system on it with MSD distributor witha rat nest of hacked wires and squirrel chews and a Performer intake.
It had a leaking accelerator pump, blown power valve and leaking accelerator pump. I serviced carb and I drove it around.
Idled fine. had no ass.
changed to rehabbed wire harness, chrome box, electronic distributor.
Starts and runs great.
Re: 340 w 750 vacuum Holley dies In gear [Re: 440PURSUIT] #2515220
06/30/18 10:52 AM
06/30/18 10:52 AM
DC, MD Suburbs
DC, MD Suburbs
Took out on shakedown, Loves the double pumper and pulls hard and revs great . Pinged a bit with more timing.
after warm and stopping to do burnouts I still have the big idle drop.
i can keep it running with a feathering.
Gotta hit a baseball tournament for the boy so I will another distributor and check running voltages later. Car is running and charging with electronic regulator but I did not look at idle voltage.\
as found alternator is in place
Fixed-72 Road Runner 340 auto [Re: 440PURSUIT] #2515565
06/30/18 09:03 PM
06/30/18 09:03 PM
DC, MD Suburbs
DC, MD Suburbs
Swapped in a MP Electronic Distributor from my 69 340 GTS Convert!
Timing at 20.
This thing idled smoothe immediately with little RPM drop.
Bar the Door Harry....here she comes!
Got it out on the street and felt real strong.
Went and gassed up at Sunoco w 93.
Got to drop the hammer a couple time and she is pulling hard!
Pretty impressed by a 340 in a B Body.
Burnouts are pit worthy!
Engine showed some inconsistencies in leak down so I'm looking forward to getting heat and run time in it and hoping this fossil starts to seal up with use.
Was definitely a custom build since inside was glyptol and heads seem gasket matched.
so far a good day and on to kick-down and other adjustments!!
Re: Fixed-72 Road Runner 340 auto [Re: 440PURSUIT] #2515775
07/01/18 11:37 AM
07/01/18 11:37 AM
You sound pumped!
Re: Fixed-72 Road Runner 340 auto [Re: 440PURSUIT] #2515915
07/01/18 04:05 PM
07/01/18 04:05 PM
CA
crackedback Offline
crackedback  Offline
CA
Sounds like mechanical advance was bleeding in and when the car was put in gear, rpm drops and the leaky mechanical adv was pulled = stalls out.
Timing is usually the issue with excessive drop when put in gear.
Cool you got it fixed up.
