Torsion Bar Question... #2514248
06/28/18 01:10 AM
06/28/18 01:10 AM
Sherwood Park, Alberta, Canada
Lighthorseman Offline OP
Hello, helpful Moparts types! Hoping someone can provide some advice here...
I recently went to install a set of MP torsion bars (Part number P5249160: 1.16 dia. bars) I purchased online many years ago, into my 1970 Satellite. These bars were purchased in 2002.
Both bars have the numbers "462R" above, with "329" below stamped onto the end of the bar.
I am under the impression that torsion bars are left and right-specific, with (duh...) the right indicated with an R, and the left with an L right there on the ends of the bars.
My questions are these...
- Due to the "462R" stamping, do I have two right-hand bars?
- If I do, considering that these bars are long since out of circulation, am I completely FUBARed?
- If they are both right-hand bars, can they still be used?
- Anything else I should know?
Thanks in advance, Moparts people!
Re: Torsion Bar Question... [Re: Lighthorseman] #2514249
06/28/18 01:14 AM
06/28/18 01:14 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Is anything stamped on the other end? If nothing on other end then:
Yes both right hand
Yes fubared
no you can't use them as a pair
Yes you can use them on the right side in 2 different cars and make hard left turns with ease.
Re: Torsion Bar Question... [Re: Lighthorseman] #2514256
06/28/18 01:34 AM
06/28/18 01:34 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If they have never been used, what is wrong with installing them? Who says that they can only twist in one direction? What makes you think that the metal knows what direction they are supposed to resist twisting?
I have swapped bars side to side and have never had a problem. The 1.0 bars I had in the Charger were pulled and swapped into a 71 Road Runner 2 years ago and I didn't put them in that car the same way they came out of mine.
We are talking a huge torsion bar here...Not some slant six, no A/C .85 bars. A 1.16 is big.
Re: Torsion Bar Question... [Re: Lighthorseman] #2514259
06/28/18 01:43 AM
06/28/18 01:43 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
torsion bar ends are clocked to some extent. At a certain thickness they no longer have that clocking and are the same, left or right. 1.16" bars fall into that category, there is no left or right.
Don't be the exception.
Re: Torsion Bar Question... [Re: Lighthorseman] #2514260
06/28/18 01:43 AM
06/28/18 01:43 AM
AndyF Offline
AndyF  Offline
If they do not have any offset then you can use them on either side. The bigger bars do not have an offset so they are not R or L. Lay the bars on a flat surface and see if each end lays flat. If so then they are not offset twisted so that means you can use them on either side.
Re: Torsion Bar Question... [Re: Lighthorseman] #2514261
06/28/18 01:45 AM
06/28/18 01:45 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: Torsion Bar Question... [Re: Lighthorseman] #2514397
06/28/18 12:56 PM
06/28/18 12:56 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
As mentioned, the larger 1"+ bars are not indexed left and right like the smaller bars are.
Re: Torsion Bar Question... [Re: Lighthorseman] #2514734
06/29/18 01:04 AM
06/29/18 01:04 AM
Thanks for all the help!
Well, as suggested by Andy, I laid them out on the floor. Sure enough, they weren't offset.
Phew!
Re: Torsion Bar Question... [Re: Lighthorseman] #2514743
06/29/18 01:10 AM
06/29/18 01:10 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Good to know learned several new things today. Seen a few broken T bars, the spiral break is cool looking.
