Looking to replace my El Cheapo air cleaner #2514706
06/28/18 11:42 PM
06/28/18 11:42 PM
Detroit Michigan
stinger Online content OP
stinger  Online Content OP
Detroit Michigan
I suspect I can get better then my e bag special air cleaner and just looking for some good ones. with all the marketing hype out there it seems hard to believe what's good. I read the you should have a min of 2" from top of carb to top of filter. I have to run a drop base and with my 3" filter I have 1.5 inches of open filter,maybe a myth I don't know?
Thanks!
Re: Looking to replace my El Cheapo air cleaner [Re: stinger] #2514712
06/28/18 11:52 PM
06/28/18 11:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Engine masters ran a big ait filter test and the best [performers were the ones that allows as straight a shot into the venturis as possible.
https://www.dailymotion.com/video/x693421
Don't be the exception.
Re: Looking to replace my El Cheapo air cleaner [Re: Supercuda] #2515013
06/29/18 06:37 PM
06/29/18 06:37 PM
Detroit Michigan
Detroit Michigan
thanks for the link,very interesting results. according to this I should block off my 14"x3" filter and add a filter top for best performance. as I expected the drop base hurts performance but maybe not if you block off the side and add a top filter like a velocity stack? something fun to try I guess....
I've read somewhere that Holley carbs like air entering from the sides more then the top though. Don't know how true that is or if it would even apply to a street car with 500 horse.
Re: Looking to replace my El Cheapo air cleaner [Re: stinger] #2515023
06/29/18 07:01 PM
06/29/18 07:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, a dyno is not an engine compartment. I would think a dual snorkel air cleaner ducted to fresh (cool) air would be best. Something like these
https://tinyurl.com/yagkf9hs
Re: Looking to replace my El Cheapo air cleaner [Re: Supercuda] #2515025
06/29/18 07:14 PM
06/29/18 07:14 PM
Detroit Michigan
Detroit Michigan
this vid https://www.youtube.com/watch?v=1KyVDUaVz-4 was not that encouraging
I did notice that he had the base mounted incorrect. the humps that were blocking his airflow are there for the Holley float bowls of course and should have been facing front and aft.
anyone have one of these cold air intake systems? please chime in!
