spiral lock inst. tool #2514362
06/28/18 11:47 AM
06/28/18 11:47 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
does any one know where to buy one thats not over 100 bucks.i dont like skimmpin on tool but thats a lot for what it is.
Re: spiral lock inst. tool [Re: bonefish] #2514368
06/28/18 11:55 AM
06/28/18 11:55 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Your talking about spiral pin locks right? Didn't know there was one. I use the smallest flat screw driver I have. The msd supplied screw driver for their switches is good too. I can do 32 locks in about 10 min.
Re: spiral lock inst. tool [Re: B1MAXX] #2514372
06/28/18 12:12 PM
06/28/18 12:12 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I'll save you 100 bucks. Watch a youtube video.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: spiral lock inst. tool [Re: bonefish] #2514380
06/28/18 12:33 PM
06/28/18 12:33 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That’s pretty good advice!!
I’m also one who uses a pocket screwdriver for that job.
It does seem that some pistons are easier to install them in than others.
Re: spiral lock inst. tool [Re: fast68plymouth] #2514385
06/28/18 12:40 PM
06/28/18 12:40 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
there is only one per side,the first side goes in perfect.the second side AINT NO WAY.the last part of the clip will not go into the groove.it looks like the pin is just a hair too long.
Re: spiral lock inst. tool [Re: bonefish] #2514390
06/28/18 12:45 PM
06/28/18 12:45 PM
PA.
"Little"John
"Little"John
PA.
Piston spec sheet should state how long of a piston pin it needs. Measure the pin and if it isn't right make a phone call to the manufacture
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: spiral lock inst. tool [Re: bonefish] #2514395
06/28/18 12:50 PM
06/28/18 12:50 PM
P
Porter67 Offline
Porter67  Offline
P
There are different versions of locks as well, like double vs triple spun so you might want to make sure you have the right locks as well.
What piston are you working with, a PN maybe?
Re: spiral lock inst. tool [Re: bonefish] #2514402
06/28/18 01:05 PM
06/28/18 01:05 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I bought one of the spiral lock removal tools, total waste of money.
A good quality (hardened tip) small screwdriver works good.
Re: spiral lock inst. tool [Re: bonefish] #2514404
06/28/18 01:06 PM
06/28/18 01:06 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Don’t buy the cheap plastic one. Waste of money.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: spiral lock inst. tool [Re: FurryStump] #2514409
06/28/18 01:11 PM
06/28/18 01:11 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
the spec sheet on these ICON pistons say pin size .9900x2.750.these pins are over 3 inches long.3.010 to be exact.
Re: spiral lock inst. tool [Re: bonefish] #2514438
06/28/18 01:49 PM
06/28/18 01:49 PM
PA.
"Little"John
"Little"John
PA.
And there you have your answer. Next step call the manufacturer
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: spiral lock inst. tool [Re: pittsburghracer] #2514452
06/28/18 02:09 PM
06/28/18 02:09 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
iagree
ICON
1-800-648-7970
Ask for Daniel or Glen
beer
Re: spiral lock inst. tool [Re: pittsburghracer] #2514455
06/28/18 02:10 PM
06/28/18 02:10 PM
PA.
"Little"John
"Little"John
PA.
Just throwing this out there but if you are assembling your pistons I assume your assembly is already ready balanced. If you need new pins you may want to weight the old ones and the new ones to see what the difference in weight is. Gram scales are cheap at Harbor Freight, Walmart, or any office supply store if you don’t have one.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: spiral lock inst. tool [Re: bonefish] #2514470
06/28/18 02:34 PM
06/28/18 02:34 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
What has ever happened to the older style 2-pin-hole clips? Those are easy to install. Can the piston supplier give you an option of the clips with the pistons? Can they be swapped and still installed into the piston?
Re: spiral lock inst. tool [Re: Mopar Mitch] #2514558
06/28/18 06:02 PM
06/28/18 06:02 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Internal snap rings are notorious for coming out.
