Re: spiral lock inst. tool
[Re: B1MAXX]
#2514372
06/28/18 12:12 PM
06/28/18 12:12 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'll save you 100 bucks. Watch a youtube video.
[Re: bonefish]
#2514380
06/28/18 12:33 PM
06/28/18 12:33 PM
fast68plymouth
So. Burlington, Vt.
That’s pretty good advice!!
I’m also one who uses a pocket screwdriver for that job.
It does seem that some pistons are easier to install them in than others.
[Re: fast68plymouth]
#2514385
06/28/18 12:40 PM
06/28/18 12:40 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
there is only one per side,the first side goes in perfect.the second side AINT NO WAY.the last part of the clip will not go into the groove.it looks like the pin is just a hair too long.
[Re: bonefish]
#2514390
06/28/18 12:45 PM
06/28/18 12:45 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Piston spec sheet should state how long of a piston pin it needs. Measure the pin and if it isn't right make a phone call to the manufacture
[Re: bonefish]
#2514438
06/28/18 01:49 PM
06/28/18 01:49 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
the spec sheet on these ICON pistons say pin size .9900x2.750.these pins are over 3 inches long.3.010 to be exact. And there you have your answer. Next step call the manufacturer
[Re: pittsburghracer]
#2514452
06/28/18 02:09 PM
06/28/18 02:09 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
the spec sheet on these ICON pistons say pin size .9900x2.750.these pins are over 3 inches long.3.010 to be exact. And there you have your answer. Next step call the manufacturer ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) ICON 1-800-648-7970 Ask for Daniel or Glen
#2514455
06/28/18 02:10 PM
06/28/18 02:10 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Just throwing this out there but if you are assembling your pistons I assume your assembly is already ready balanced. If you need new pins you may want to weight the old ones and the new ones to see what the difference in weight is. Gram scales are cheap at Harbor Freight, Walmart, or any office supply store if you don’t have one.
[Re: bonefish]
#2514470
06/28/18 02:34 PM
06/28/18 02:34 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
What has ever happened to the older style 2-pin-hole clips? Those are easy to install. Can the piston supplier give you an option of the clips with the pistons? Can they be swapped and still installed into the piston?
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2514558
06/28/18 06:02 PM
06/28/18 06:02 PM
Posts: 26,004 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Internal snap rings are notorious for coming out.
