1970 B Body Rear defrost/top switch
#2513737
06/27/18 12:33 AM
06/27/18 12:33 AM
Posts: 367 Akron, Ohio
VegasCharger
Akron, Ohio
Hello, so I bought a complete 1970 B Body standard dash frame and it has a rear defrost switch. When I removed the switch I noticed on the other side of the button there was the wording "TOP" on it. Did Chrysler use the same switch set-up for both rear defrost cars and convertibles? Just flipped the button to the specific application? Same switch? Wiring? pics below Thanks in advance.
Re: 1970 B Body Rear defrost/top switch
[Re: VegasCharger]
#2513839
06/27/18 11:47 AM
06/27/18 11:47 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
That not rear defrost.
That is for the power rear window in a station wagon.
68-69 are the same way with a large rocker switch handle put on the same basic switch.
68-72 Oldsmobile is same way. I suspect many other manufacturers did the same thing.
Bummer 67-69 Abodies didn’t have a wagon in US. So no cars to scab those from.
[Re: autoxcuda]
#2514013
06/27/18 05:09 PM
06/27/18 05:09 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Bummer 67-69 Abodies didn’t have a wagon in US. So no cars to scab those from. That's funny it looks exactly like the one in my 70 hemi GTX
[Re: VegasCharger]
#2514031
06/27/18 05:36 PM
06/27/18 05:36 PM
VegasCharger
Akron, Ohio
Thanks for all of the replies thus far. So it looks like it might be a 3 in 1 switch. 1. Rear Defrost 2. Top 3. Rear PW for wagons So "R. WIND." meant rear window either for defrost on a non wagon car or for power window on a station wagon car. What if you wanted rear defrost for a rear power window on a station wagon lol? JK
[Re: Morty426]
#2514229
06/28/18 12:28 AM
06/28/18 12:28 AM
autoxcuda
So Cal
Here is a picture - unrestored car
A station wagon rear window switch is momentary switch. When you let go of it, it goes back center to the off position. One direction is up the other is down. Just like a door power window switch. Power top switches are the same. All the defogger switches I have/had 71-74 B-body, 67-up A-body and E-body have three positions: off, low, high. And they click and stay in each position. I think the 70 defogger switch shown just uses the lever and case from a power top and rear station wagon window. Not the switch internals itself. Craig, Barry, VegasCharger: do your defogger switches return to the center off position when you let go of them? Or do they have click to hold them in each position? JS Restorations
[Re: autoxcuda]
#2514266
06/28/18 02:30 AM
06/28/18 02:30 AM
Morty426
Sacramento CA
A station wagon rear window switch is momentary switch. When you let go of it, it goes back center to the off position. One direction is up the other is down. Just like a door power window switch. Power top switches are the same. All the defogger switches I have/had 71-74 B-body, 67-up A-body and E-body have three positions: off, low, high. And they click and stay in each position. I think the 70 defogger switch shown just uses the lever and case from a power top and rear station wagon window. Not the switch internals itself. Craig, Barry, VegasCharger: do your defogger switches return to the center off position when you let go of them? Or do they have click to hold them in each position? JS Restorations My switch is three positions with detents.
[Re: VegasCharger]
#2514316
06/28/18 09:51 AM
06/28/18 09:51 AM
Posts: 601 Mass
charge70
Mass
The knob/button is the same,the switch is definitely not the same.The size of the wire is smaller on the defog switch compared to the power top switch.The wagon rear window and p-top switches may be the same,I'm not sure.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
