Re: Low comp 440 [Re: cudaman1969] #2513960
06/27/18 03:11 PM
06/27/18 03:11 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
A couple questions on the 509 you guys have, what rpm do you shift at and thru the traps, what springs? I've always used the Isky steel rockers and Crane pushrods.
All cam makers say their cams are the greatest and I have always liked the 509 but I'm leaning toward the new technology to see which has better cylinder filling with a reg hydraulic lifter and be better all around.
Re: Low comp 440 [Re: cudaman1969] #2513979
06/27/18 03:42 PM
06/27/18 03:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m sure you’ve built enough motors to have a pretty good handle on what to use to get it to have the balance of power and drivability you’re looking for.
Re: Low comp 440 [Re: fast68plymouth] #2514032
06/27/18 05:40 PM
06/27/18 05:40 PM
fredericksburg,va
fredericksburg,va
I did this engine back in 85, just ain't up on the new stuff, reason I'm relying on you guys in the know to point me in the right direction. Believe me, I will listen, I like the details.
Re: Low comp 440 [Re: cudaman1969] #2514038
06/27/18 05:46 PM
06/27/18 05:46 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
You may be thinking of the Thumpercams.
Re: Low comp 440 [Re: cudaman1969] #2514235
06/28/18 12:42 AM
06/28/18 12:42 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By cudaman1969
The reason I'm asking is I had read before about some cam company who makes a cam for these low comp engines with a radical sound. Can't remember witch one, just looking for feedback if someone had used one and had results. When a race car it would stop pulling at 5000, this same cam in my 383 HC, would go 7000 easy, still pulling. Cam is over 40 years old. Cams should be better now.
Cams are a little better now, but mostly they are better with street driving characteristics. The 509 is waay to big for what you want. Its a Great performance cam with a 4200+ vert, but no way would I want it for a primary street car even with a stick with a low comp engine.
Re: Low comp 440 [Re: cudaman1969] #2514360
06/28/18 11:45 AM
06/28/18 11:45 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Comp 924, shift 5700, not sure on trap rpm but went 116. 4.56 gears 31" tires, 9' GER converter that was rebuilt locally. I hadn't started the car for several months, tapped the gas twice kit the key, and it fired right up and idled. Timing is 25 at idle and 36 when in.
Re: Low comp 440 [Re: cudaman1969] #2514387
06/28/18 12:43 PM
06/28/18 12:43 PM
So. Burlington, Vt.
So. Burlington, Vt.
One of my favorite street/strip 440 cams is the Comp xs282s, which is technically probably slightly on the big side for the OP’s combo......... but would still offer better drivability and vacuum over the 509 cam.
Re: Low comp 440 [Re: cudaman1969] #2514400
06/28/18 01:04 PM
06/28/18 01:04 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
mechanical cam will work better in all aspects. a small to moderate mechanical would be the ticket. I was impressed by a xs274s I rode in several months ago.
Re: Low comp 440 [Re: lewtot184] #2514420
06/28/18 01:28 PM
06/28/18 01:28 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
The .528/284 MP mechanical that AndyF mentions frequently would be a great selection.
I ran it in a stock ring/bearing 9:1 440 engine with 2500 stall and 3.23 gears. It was an torque monster that got mileage to boot. 14mpg!
'63 Dodge 330
11.19 @ 121 mph
Re: Low comp 440 [Re: GY3] #2515033
06/29/18 07:35 PM
06/29/18 07:35 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
iagree
with the above posts that if you are going to get a new cam ........solid no-doubt. I ran the 509 cause it was laying around.
Re: Low comp 440 [Re: cudaman1969] #2515042
06/29/18 07:54 PM
06/29/18 07:54 PM
fredericksburg,va
fredericksburg,va
I'm buying this one from a guy who contacted me...
"Comp 3bolt cam ..505 intake lift…511exhaust lift intake duration 230 …exhaust duration246 to be installed at 109 intake centerline. Also new Comp lifters (better ones)#867. I had a low pop engine and had Jeff at Modern spec it out."
Sound ok? Hope so.
Re: Low comp 440 [Re: cudaman1969] #2515047
06/29/18 08:10 PM
06/29/18 08:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
230/246@.050??
16 extra degrees on the exhaust....... interesting.
I’m sure it will run “fine”, but without dyno testing it against something else..... you won’t know if that’s what the motor really wants or not.
When you get it, post the lobe numbers.
Re: Low comp 440 [Re: cudaman1969] #2515057
06/29/18 08:42 PM
06/29/18 08:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
numbers don't match up to any master lobe stuff I have.
Re: Low comp 440 [Re: cudaman1969] #2515070
06/29/18 09:03 PM
06/29/18 09:03 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’m gonna go with......
5087/5209
