Re: Breaking in a race engine
[Re: The Sphinx]
#2513727
06/26/18 11:59 PM
06/26/18 11:59 PM
Posts: 4,457 Washington
madscientist
Washington
I just put together an engine for my race only car. Aluminium headed 360 12 to 1 compression with a solid flat tappet cam around .670 lift and duration at 265 at .050. I just broke the cam in by running it for 22 minutes between 1800 and 2500 rpm. I vary rpm during cam break in. I just installed the inner springs, anything else I should do before next Sundays race? How do ya'll break in a race engine? Time to run it.
[Re: The Sphinx]
#2513728
06/27/18 12:03 AM
06/27/18 12:03 AM
Posts: 11,686 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Change oil, look at the filter for anything bad, run the valves again, double check timing, everything tight.
[Re: CMcAllister]
#2513730
06/27/18 12:19 AM
06/27/18 12:19 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I use tranny fluid on my cylinder walls on assembly so by time it hits the track it’s pedal to the metal. Race time
[Re: The Sphinx]
#2513988
06/27/18 03:59 PM
06/27/18 03:59 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've certainly taken a fresh engine - with maybe 5 minutes of run time - down the road to a race out of necessity. I prefer to take it to the track, put a couple of 1/8 mile hits on it, take it home and change oil, look at the filter, double check adjustments and valves, etc. before racing it. Be different if it had been on a dyno.
[Re: The Sphinx]
#2514029
06/27/18 05:32 PM
06/27/18 05:32 PM
Posts: 4,210 New York
polyspheric
New York
Back in the day, race engines would be stripped after a race and re-ringed (same size) because the walls had assumed their "as-stressed" shape and ring seal would improve. Harley-Davidson did this as far back as 1955.
Boffin Emeritus
[Re: polyspheric]
#2514034
06/27/18 05:41 PM
06/27/18 05:41 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Back in the day, race engines would be stripped after a race and re-ringed (same size) because the walls had assumed their "as-stressed" shape and ring seal would improve. Harley-Davidson did this as far back as 1955. And this means what? Should us bracket racers go out for a day of Racing and then tear it all apart and rebuild it for next week. Cheese and rice stay on point. Lol. Build it right, race the dog gone thing, and have fun. Don’t over think it.
[Re: The Sphinx]
#2514086
06/27/18 07:34 PM
06/27/18 07:34 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I've always broke new motors in as they were ment to work and race motors are no exception.
Have a great day Iowan
"obsolete is neat"
[Re: tboomer]
#2514150
06/27/18 10:12 PM
06/27/18 10:12 PM
Iowan
Lost in Time
Iowan..Don't know where you are from but when my motor was done we went to Humboldt and beat it pretty good! Up around the Mason City area, about an hour from Cedar Falls Raceway.
"obsolete is neat"
[Re: The Sphinx]
#2514240
06/28/18 12:52 AM
06/28/18 12:52 AM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
Read an article about cycle racing. The guy built two engines identical, first one did about tweenty laps very easy. Second, full throttle the whole race. After the "break in" fist bike never could run as fast as the second. After the season tore both down, first one was black, dirty inside, second just like new. The full throttle made the rings seal better so no blow by. The old adage, run it like you stole it off the showroom floor works. All out and don't look back.
