AAR T/A Exhaust Hanger #2512932
06/25/18 10:37 AM
06/25/18 10:37 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Heres a long shot . . .
Has anyone found fiber reinforced rubber that is close to the original material used on the AAR-T/A Exhaust Hangers?
I'm looking to replace mine and would really like to keep the material as close to original as possible, note the ribbed pattern on one surface, similar to the inside of a tire, and the smooth opposite surface.
Scoured the internet but not wild about ordering large quantities from India or China, thought maybe an old corded tire (no steel belts)?
The rubber measures .307'ish thick.
Really hoping to pull a rabbit from a hat on this one, any help is appreciated.
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2512991
06/25/18 01:05 PM
06/25/18 01:05 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I have a brand new set unopened still in plastic I bought from Year One Part Number E68LHRH a few years back if that would help.
PM me for details
Thanks!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: AAR T/A Exhaust Hanger [Re: RylisPro] #2513055
06/25/18 03:06 PM
06/25/18 03:06 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I may be able to help.
These NOS B-body hangers have same width and thickness but I need to know length of the rubber on yours.
Some have the ribbed surface on one side but have two rivets on top and one on bottom.
I dont think A-body hanger rubber is long enough
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2513086
06/25/18 04:26 PM
06/25/18 04:26 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
.3 X 3” X 5”
Pattern looks a bit different but I’ve seen both, sort of like the rivet differences that exist.
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2513147
06/25/18 06:42 PM
06/25/18 06:42 PM
GMP440 Offline
GMP440  Offline
How about finding an old bias ply trailer tire, cut the rubber piece you need and mount it to the hanger. That's what I'm doing with and original hanger. It will also show the threads like the originals.
Re: AAR T/A Exhaust Hanger [Re: GMP440] #2513168
06/25/18 07:22 PM
06/25/18 07:22 PM
MD
floyd Offline
floyd  Offline
MD
Bias ply sounds like a good idea.
Here's some pics of a NOS set for more examples
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2513312
06/26/18 01:03 AM
06/26/18 01:03 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Bias ply tire has crossed my mind but I’m unsure if the thickness will be .30 after removing the tread.
Also not sure how to remove the tread and get the smooth finish the originals had.
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2513450
06/26/18 01:00 PM
06/26/18 01:00 PM
moparx Offline
moparx  Offline
maybe cut the sidewall out of a truck tire ? i don't know if a guy would have to use an over the road tire, or an "x?" ply LT tire. maybe even a trailer tire. no tread removal would be necessary if the sidewall was [close to] the correct thickness.
beer
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2513539
06/26/18 04:16 PM
06/26/18 04:16 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Looks like a salvage yard run with a box cutter or jab saw.
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2513818
06/27/18 10:58 AM
06/27/18 10:58 AM
WV
Little Detroit Offline
WV
you guys need to think outside the box, a little. the material you are looking for is conveyer belting as used in grain and coal conveyer belts. its an industrial product still in common use, the "ribbing" on the back side is for grip or traction to keep the from slipping during inclement weather. whether you living farming or coal territory you should be able to find used belting either from implement sale or grain and coal processors. or you could buy new from either Goodyear or firestone.
Re: AAR T/A Exhaust Hanger [Re: Little Detroit] #2513824
06/27/18 11:12 AM
06/27/18 11:12 AM
moparx Offline
moparx  Offline
well, there ya go ! maybe someone can post a pic or two to compare against ?
beer
Re: AAR T/A Exhaust Hanger [Re: moparx] #2513842
06/27/18 11:53 AM
06/27/18 11:53 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
If all else fails, I have access to hundreds of different NOS hangers with that type of rubber, some with the round opening.
It is a bit of a drive for me but I go there occasionally and am sure I can get what you need pretty cheap, except the rivets would have to be removed since the metal ends are Ford and GM, some Mopar...no E body left.
Re: AAR T/A Exhaust Hanger [Re: Little Detroit] #2514121
06/27/18 08:58 PM
06/27/18 08:58 PM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
I like the way you think, I searched all over for “fiber reinforced rubber”, so looking for elevator rubber will give me another avenue to check, though a quick search appears to have the same issue I ran into before, large quantity. Another quick observation is the back pattern may be difficult to near impossible to find. That all said I’ll spend time tonight looking.
I’m planning a salvage yard run this weekend and will hope to find something useful on that trip as the price will be greatly reduced
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2514132
06/27/18 09:23 PM
06/27/18 09:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Terry, if any of that NOS is for 1970 A, B or C-body 4-door applications, I would love to know.
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2514330
06/28/18 10:52 AM
06/28/18 10:52 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
The search for conveyor belt material in the correct thickness and pattern is exhausting and near impossible, then theres the issue of buying in small quantity. While it or fiber reinforced rubber are certainly functional options, trying to get a legitimate match to original in a correct thickness and pattern is like finding a needle in a haystack.
I'm keeping my fingers crossed that the salvage yard run is prosporus
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2515697
07/01/18 01:23 AM
07/01/18 01:23 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Thought I'd give an update on the junk yard run, basically struck out. While AZ is great for steel, its horrible for rubber. The search continues . . .
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2515707
07/01/18 01:35 AM
07/01/18 01:35 AM
P
Porter67 Offline
Porter67  Offline
P
Older mud flaps is the ticket, did it in the mid 90-s on a set.
I might have pics and will look.
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2515770
07/01/18 11:07 AM
07/01/18 11:07 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Agree a mud flap may be functional but I suspect it will not carry the look of an original piece of fiber reinforced rubber. Note the top photos where one surface is pretty smooth and the other is ribbed.
I do appreciate the ideas and will keep looking
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2515789
07/01/18 11:56 AM
07/01/18 11:56 AM
MO
cdp Offline
cdp  Offline
MO
If you have a farm store near you, like Orschelns, etc, you should find some flat belt material for hay bailers, PTO belts, etc. I live in a small farm town and our local hardware store carries it in bulk. Roll it out by the foot. Its worth a try, because its fairly reasonable.
Re: AAR T/A Exhaust Hanger [Re: AAR#2] #2515946
07/01/18 05:17 PM
07/01/18 05:17 PM
P
Porter67 Offline
Porter67  Offline
P
If you cant find the pattern, make it.
A plainer blade isnt too costly. Chuck that blade in a mill and make any consistent pattern you like on it. Then go cut your one side that way.
Find the right material and make a bucketful.
