Burned Ram 3500 identification #2513345
06/26/18 03:29 AM
06/26/18 03:29 AM
dogdays Offline OP
dogdays  Offline OP
Someone dumped a Ram 3500 on my property. No plates, and the cab and part of the engine compartment are burned. It has a steel flatbed and probably was a weldor's truck. It hs a V10 engine and a transfer case putting the front driveshaft under the driver. It has a Dana 80 rear with 4.10 gears. Dual tires. Regular cab.
The VIN plate was destroyed and there is nothing left in the cab or under the hood that easily identifies the truck. The door and jamb are bare except for some ashes.
Where would I find a VIN on this hulk? Any other way to identify? There is a tag on the rear end with a part number. Would this help?
Thanks!!!
Re: Burned Ram 3500 identification [Re: dogdays] #2513398
06/26/18 10:35 AM
06/26/18 10:35 AM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
check radiator support.
Also ive heard either bottom of passenger side frame rail, in area of transfer case or top of frame rail around drivers door area.
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: Burned Ram 3500 identification [Re: ViperDave] #2513440
06/26/18 12:47 PM
06/26/18 12:47 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
If you know a LEO there are hidden tags that help them ID burned vehicles. Not sure when manufacturers started doing it though. work
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Burned Ram 3500 identification [Re: I_bleed_MOPAR] #2513501
06/26/18 02:35 PM
06/26/18 02:35 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
Should be a Vin tag welded to the floor under the passenger seat.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Burned Ram 3500 identification [Re: dogdays] #2513526
06/26/18 03:44 PM
06/26/18 03:44 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
It should be pin etched on the frame rail on the passenger side lower flange near the trans/tcase.
Re: Burned Ram 3500 identification [Re: dogdays] #2513531
06/26/18 03:53 PM
06/26/18 03:53 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
No VIN on the engine?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Burned Ram 3500 identification [Re: dogdays] #2513534
06/26/18 03:57 PM
06/26/18 03:57 PM
dogdays Offline OP
dogdays  Offline OP
Im sure there is but I don't have a way to get to it. I'll look unde the passenger seat
R.
Re: Burned Ram 3500 identification [Re: dogdays] #2513766
06/27/18 02:06 AM
06/27/18 02:06 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
the round tag on the t case should have a date on it
my ladder of success is missing some rungs
Re: Burned Ram 3500 identification [Re: 73MagDuster] #2514057
06/27/18 06:33 PM
06/27/18 06:33 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Correct. up
Look there, the VIN is pin etched into the frame.
It was done fairly early on the chassis line (frame component assembly) in the plants.
Re: Burned Ram 3500 identification [Re: dogdays] #2514064
06/27/18 06:58 PM
06/27/18 06:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Possibly a dumped stolen, just call your local state police & let them look into it.
Re: Burned Ram 3500 identification [Re: dogdays] #2514308
06/28/18 09:36 AM
06/28/18 09:36 AM
scratchnfotraction Offline
I agree, call local LEO. no need to be poking around in WHAT could be a piece of crime scene evidence being covered up and dumped.
surly you watch crime shows on TV?
poking around in it with out first reporting it could make you a "Accessory after the fact" in a crime.
at least get you a ride down town and under a hot light bulb with tie and suites water boarding you.
if you figure finders keepers then file a illegal dumping report and after 30 days it becomes yours....just pick it up from impound.
Re: Burned Ram 3500 identification [Re: dogdays] #2514854
06/29/18 11:35 AM
06/29/18 11:35 AM
Wichita Kansas
6PacCuda Offline
6PacCuda  Offline
Wichita Kansas
If I remember right, the cab vin will be stamped on the edge of the cowl, on the passenger side.
Re: MYSTERY SOLVED!!! Burned Ram 3500 identification [Re: 6PacCuda] #2517984
07/05/18 02:57 PM
07/05/18 02:57 PM
dogdays Offline OP
dogdays  Offline OP
Well, the mystery is solved. The owner came one afternoon and claimed it. I was already getting offers on it from the neighbors! But the owner told me the story of how it ended up in my yard.
It was late at night and he was driving home in his trailer pulling truck when he noticed flames coming out from under the dash. This was in the boonies, 15 miles from the nearest town of 678 souls, four miles from my farmyard. He stopped in the middle of the road, jumped out and watched it burn. Fortunately for him he remembered to grab his cellphone.
He called the only guy he knew crazy enough to come and rescue him and Wayne (his real name) brought a wrecker and hooked up. Wayne was an old friend of the family and had visited my Dad many times while Dad was alive. So he knew it would be safe in the farmyard until the owner could tow it away. Towing it back to Wayne's yard (almost said Wayne's World)would have taken it miles out of the way.
While it was still on the hook Wayne removed the front wheels thinking they would be a target for theft.
I told the owner there was no hurry getting the truck out of the yard as no one lives there. He was trying to figure out how to hook it to a 3-point hitch on one of his tractors as I drove away.
So no need for CSI or FBI, just an unlucky farmer.
R.
