1992 D250 VS 2014 Ram 1500 towing comparison... #2512066
06/23/18 09:37 AM
06/23/18 09:37 AM
Bowling Green KY / Nashville, ...
300by500 Offline OP
300by500  Offline OP
I've got a 1992 Cummins 5-speed D250, and I occasionally tow vehicles heavier than a car. I like it, but it lacks a lot of modern creature comforts that newer trucks have.
I can't wrap my head around paying $70K for a new Cummins truck, or even $30-$40K for a used one. So I started looking into the tow capacity of newer lighter-duty trucks and discovered something interesting.
From the info I've found, the towing capacity for my '92 Cummins 5-speed 2500 is listed as right around 11,900 lbs.
The towing capacity for a 2014 Ram 1500 with a Hemi is 10,450 lbs.
Both capacity ratings are higher than my 10,000 lb trailer capacity.
Has technology advanced to the point that 1/2 ton trucks are that much beefier than they used to be, or has something changed in how the "official" towing capacities are rated?
My 1998 Dodge 1500 is only rated at 7800 lbs.
Anyone with real-world experience want to chime in?
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: 300by500] #2512078
06/23/18 10:25 AM
06/23/18 10:25 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I can say that my 2014 Ram with a 6600lbs loaded trailer stops better than my moms 91 D350 5 speed with the same trailer and car on it.
I need more trailer brake with the 91 than the 2014 , both RCLBs
That's my only experience between the 2 .
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: 300by500] #2512082
06/23/18 10:46 AM
06/23/18 10:46 AM
E
earlymopar Offline
earlymopar  Offline
E
I can comment a bit based on my experiences and research. I have a 2016 1500 with the ECO-Diesel and I tow a (dry weight) trailer of 6400 lbs. The trailer has a 750 lb tongue weight.
The first thing that I found is that the newer RAMs are actually rated at over 3/4 ton versus the 1/2 ton category they're in (1500 model). I found this after I noticed newer RAM 2500s with similar trailers to mine, had a similar ride height after being hooked to their trailers. My ride height (with trailer connected via a load-distribution hitch) was slightly lower in the rear. I simply opted to add air bags to even up everything. Running 25 lbs in the bags is all that is needed.
As ric3xrt noted, the brakes on these truck are incredible and of course having good trailer brakes is a must.
The other things that help out a great deal are, the 8-speed transmission and the Tow / Haul setting that holds the transmission in gears longer before shifting. Certainly, rear end ratio and tire size are other factors.
- EM
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: 300by500] #2512099
06/23/18 11:36 AM
06/23/18 11:36 AM
Guitar Jones Online laugh2
I've seen a lot of newer 1500's towing heavier trailers. Trailer brakes and the integrated controllers help a lot on these vehicles. I have modified my 92 D250 club cab CTD auto with rear discs, a lock up converter and soon to have a hydroboost conversion. With the more advanced trailer brake controllers on the market today I love my 92. Stops as well as the 06 2500 QC CTD 4WD I had and the 07 GMC *cough* 3500 4WD crew cab I had.
Creature comforts? I have A/C, cruise, power locks, windows and a stereo with bluetooth and an aux input. I even have a Garmin navi unit if I need it. And I know the fuel mileage is better than any of those other trucks and it's paid for. So what else do I really need? Oh yeah, 4 doors, but I have the crew cab Power Wagon for those outings with the wife and dogs. Maybe someday I'll combine them all in to one truck but not now.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: earlymopar] #2512101
06/23/18 11:36 AM
06/23/18 11:36 AM
God's Country Maryland
GODSCOUNTRY340 Offline
The main difference you'll find is the Hemi (if auto) will constantly be shifting when towing something heavy, not enough torque.
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: 300by500] #2512199
06/23/18 03:02 PM
06/23/18 03:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
you can always multiply TQ to get more but whatever HP you have you are stuck with, so what if it shifts sometimes?
Another thing that helps the newer trucks handle bigger trailes is the vehicle weight and footprint, they are wider, longer and heavier, all help with the overall ability to manhandle the trailer behind it. I noticed also that my 2011 1500 was much more stable towing trailers with 20" wheels than the 17"s, less sidewall flex means better control of everything.
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: 300by500] #2512291
06/23/18 08:04 PM
06/23/18 08:04 PM
300by500 Offline OP
300by500  Offline OP
1992 D250: 160 HP, 400 ft. lbs. torque
Ram 5.7 Hemi: 347 HP, 407 ft. lbs. torque
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: 300by500] #2512301
06/23/18 08:38 PM
06/23/18 08:38 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Currently the owner of a 92 D250 Cummins with automatic and former owner of a 11 1500 Crew cab I can offer some insight.
Short version, the 11 tows faster but the 92 is much more stable.
Long version, both trucks are factory rated for a 12000 gcvw. The 92 is transmission limited by the factory but manual trans trucks were rated as high as 17000 gcvw. Both have 3.54 gearing. Both are between 5500 and 6000 lbs empty so up to a 6500# trailer.
Trailer in this case is either a 28' camper or an 18' car hauler.
Clearly the horsepower advantage is with the 11, much more nimble in traffic and merging, maintaining speed on hills better. But it just felt so unstable even with sway control and weight distribution. Non tow mirrors sucked too.
The 92 took more forethought into merging and plan on staying in the slow lane on hills. But the mirrors are much better (standard tow mirrors not giant west coast) and the whole rig just feels more stable, even without sway control or distribution.
These are comparisons based on making the same trip several times with each truck.
We sold the 11.
Angry white pureblood male
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: ruderunner] #2512402
06/24/18 12:19 AM
06/24/18 12:19 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have an 84 crew cab D350 with a 91.5 intercooled Cummins and a 727 with gear vendors overdrive and my 2015 2500 4x4 regular cab 5.7 Hemi Ram tows, stops, and pretty much does everything better than the one ton crew cab and tows 11,870 lbs. The only thing it lacks is fuel mileage, but with diesel being higher than gas now it is becoming a wash. Probably won't have the Cummins too much longer. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: 300by500] #2512407
06/24/18 12:23 AM
06/24/18 12:23 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My 2015 is 383 HP 400 ft lbs, strange they upped the hp and lowered the torque... shruggy
A-Body's RULE!
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: Rhinodart] #2512412
06/24/18 12:33 AM
06/24/18 12:33 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I think the frame and brakes are not too bad on the newer 1500's. The stock coil spring suspension should have been left on Chevys where it belonged. The stock coils are more suited for mall duty than hauling anything. The sway bars are pretty thin on the 1500 as well. I bought an 18 1500 as it is good enough to tow with once in awhile but I bought a set of airbags for it. I really prefer a diesel for towing as on a hill they just hunker down and pull whereas you feel like you are beating the heck out of a gas motor pulling a load up a hill.
So bottom line is I preferred my Cummins trucks for towing but for occasional tow duty the 1500 will handle it. Here is my 15 1500 with an empty 26 foot on with the wonderful stock coils.
I used this 1500 and that 26 footer on my last move. It involved hauling the 26 footer with my Viper once and my Twin Turbo Stealth another time with other shop stuff loaded in the trailer as well. Two long hills on this trip one of which is 8 percent and runs for about 15 miles. I hated the engine in that 15 and I can tell you if it was possible to break it I would have. She started to finally run better after the moves but I got rid of the truck anyway. Bottom line is a gas 1500 will do what you need it to do.
Sheldon
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: 300by500] #2512911
06/25/18 09:05 AM
06/25/18 09:05 AM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
So I just sold my 14 crew 1500 hemi/8spd and went to a 90 d350 dually.
The main reason is that I didn't need a truck payment on a truck that gets 3-4K miles a year.
That being said, it definitely pulled better than my d350 in terms of getting on the highway. This being an open car trailer with a diesel truck on the trailer The d350 does sit nicer with trailer.
But I would not hesitate to go back to a new 1500 gas. It pulled nicely. and definitely had power. and for the record 1500s hemi is a 395hp 407 ft lbs.
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: 300by500] #2512957
06/25/18 11:55 AM
06/25/18 11:55 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I have a 2002 Cummins with the HO & 6spd manual and a 13 longhorn 1500. While both are rated to TOW . . . you have to look at the carrying capacity. The 1500's are ONLY going to be around 1300lb. Put a 700lb tongue weight and then yourself in truck, and then anyone else, stuff in the box, etc, you can see where you quickly are BEYOND the carrying capacity (according to Ma Mopar) of the 1500. However, check rating on your Cummins - it will tow the trailer, as well as you and your stuff. Sure the Longhorn I have tow my travel trailer fine, but the Cummins does it "with ease" compared to hearing the Hemi and the 8spd Auto shifting . . . must say, would rather tow with a Cummins, and 3/4 ton !!! Don't be fooled by "how much you can tow", you have to look at ALL the ratings !!! It's all the manufacturer's doing it . . .
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: a12rag] #2513059
06/25/18 03:16 PM
06/25/18 03:16 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
An 02 HO is very different beast from a 92
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: HotRodDave] #2513411
06/26/18 11:18 AM
06/26/18 11:18 AM
Yes it is but there is just under 2 tons of cement in this truck. Show me a 1500 anything that will do this.
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: HotRodDave] #2513931
06/27/18 02:36 PM
06/27/18 02:36 PM
a12rag Offline
a12rag  Offline
That is true . . .but what I am getting at is the actual GVW rating between trucks. Don't think that the "newer" Ram 1500 are great . . . look at the Ram forum and you will find most are not happy with the "low" GVW rating of the 1500. I would think that the 92 250 would have much better GVWR than a newer 1500 - they are ONLY a 1/2 ton (1000lb) rated machine. The concept of the 1500 (or any 1/2ton) towing up to 12,000lb, is more than just the engine/tranny, brakes . . . especially if you get pulled over by the troopers.
In British Columbia, years ago, the provincial truck cops, were pulling over every "light truck" and weighing them - any 1/2 ton with a camper in the back was turned back and not allowed on the roads in BC . . . according to the manufacturer's GVWR the trucks were overloaded ! . . .
Just my two cents worth . . .
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: Guitar Jones] #2514213
06/28/18 12:00 AM
06/28/18 12:00 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I brought home 48 80lbs sacks of concrete in my wife's 05 1500 QC and it sat level. That's 3840lbs and it was in one trip and 3840 lbs exceeds the rated bed capacity of any 1/2, 3/4, or 1 ton for the high horse riders out there.
Don't be the exception.
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: Supercuda] #2514270
06/28/18 02:54 AM
06/28/18 02:54 AM
You know the rules. Pics or it didn't happen.
I find it very hard to belive that all that weight was in the bed of that 1500 and it sat level without some help from something. The 05 also doesn't have coil springs like the new trucks do. But beyond that there is more to the heavier rated trucks than just what the springs will hold like the axles and brakes.
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: 300by500] #2514923
06/29/18 01:53 PM
06/29/18 01:53 PM
E
earlymopar Offline
earlymopar  Offline
E
I know my 2016 1500 1/2 ton is actually rated over 1600 lbs (over 3/4 ton). I assume the 2500 has a similar "over-rating" .
- EM
Re: 1992 D250 VS 2014 Ram 1500 towing comparison... [Re: earlymopar] #2515008
06/29/18 06:33 PM
06/29/18 06:33 PM
- EM
Yes they do, my D250 is rated at a GVR of 9800 pounds. These trucks only weigh about 5000 pounds empty.
