No Shift/IAC #2511518
06/21/18 10:35 PM
06/21/18 10:35 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
89 Dakota 3.9 auto. Suddenly the trans won's shift into 3rd. Fluid level is full and clean. No burnt smell. Then when stopping at a light/stop sign it will stumble, but not stall. I remember reading something about the IAC being tied into the trans shifing??
Grandma always said I had "hands of gold"!
Re: No Shift/IAC [Re: CHRGR69] #2511551
06/22/18 12:02 AM
06/22/18 12:02 AM
A727Tflite Offline
A727Tflite  Offline
Normal reverse operation ?
4 speed I assume or 3 speed ?
First thing to check if reverse works is the throttle pressure linkage/cable.
Open the throttle engine off to wide open then release. Make sure the throttle pressure cable and lever at the trans returns all the way forward.
There should be a spring on the lever at the trans that returns that lever forward.
If no reverse then things get more complicated.
Re: No Shift/IAC [Re: A727Tflite] #2511563
06/22/18 12:23 AM
06/22/18 12:23 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
3 speed with the OD on off button? Reverse is fine.
Re: No Shift/IAC [Re: CHRGR69] #2511781
06/22/18 03:34 PM
06/22/18 03:34 PM
Guitar Jones Offline
1st, 2nd, and 3rd are hydraulically controlled. O/D is controlled by a solenoid.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: No Shift/IAC [Re: CHRGR69] #2512166
06/23/18 02:01 PM
06/23/18 02:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When it won't shift to 3rd, try accelerating a little more and then throttling back to idle; will it shift then?
Re: No Shift/IAC [Re: John_Kunkel] #2512654
06/24/18 04:38 PM
06/24/18 04:38 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
I tried it, but hard to tell if it shifted. I'm leaning toward saying yes, because it didn't stumble when I came to a full stop.
Re: No Shift/IAC [Re: CHRGR69] #2512800
06/24/18 11:12 PM
06/24/18 11:12 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Thinking front piston seals John?
Re: No Shift/IAC [Re: J_BODY] #2513135
06/25/18 06:16 PM
06/25/18 06:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Front clutch seal/rings or governor sealing rings.
A strong Reverse isn't always a good gauge of front clutch operation; the line pressure triples in Reverse so a weak clutch will often work acceptably in Reverse.
Re: No Shift/IAC [Re: John_Kunkel] #2513871
06/27/18 12:58 PM
06/27/18 12:58 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
I finally got around to pulling codes and I got a "DTC:15 NO VEHICLE SPEED SENSOR SIGNAL DETECTED DURING ROAD LOAD CONDITIONS". A symptom of this sensor failing are "can cause an automatic transmission to go into limp mode, and not shift above second gear". Think I found my problem.
Re: No Shift/IAC [Re: CHRGR69] #2514115
06/27/18 08:43 PM
06/27/18 08:43 PM
No you didn't if you are accurately describing the condition. Since you don't have an electronically controlled transmission there isn't a "limp mode". No speed sensor signal will result in no 4th gear shift but it has nothing to do with the 1/2 or 2/3 shift. Please try to accurately describe the condition you are trying to fix if you want accurate information to fix it.
Re: No Shift/IAC [Re: Guitar Jones] #2514353
06/28/18 11:39 AM
06/28/18 11:39 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
From a dead stop, when I accelerate, is that 1st gear? If so, I than feel 2 more shits after that, and than it hangs up (4th gear?). Maybe I did describe it wrong. I thought these were 3 speed transmissions.
Re: No Shift/IAC [Re: CHRGR69] #2514575
06/28/18 07:23 PM
06/28/18 07:23 PM
I replied to your PM. Don't want to type all over again, I'm on my tablet. laugh2
Re: No Shift/IAC [Re: Guitar Jones] #2514937
06/29/18 02:24 PM
06/29/18 02:24 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Got it! Thanks
Re: No Shift/IAC [Re: CHRGR69] #2518439
07/06/18 03:09 PM
07/06/18 03:09 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
UPDATE! Sensor installed, trans shifting normally again!
