interior paint #2512229
06/23/18 04:09 PM
06/23/18 04:09 PM
Toronto, Canada
67fastfish Offline OP
Toronto, Canada
hello All,
New to the forum, need help to find interior paint, for my 67 Cuda?
can someone please help me find the right paint code and where to buy the paint for my car. I am sure I'm leaving some info out. I have the fender tag interior is a dark blue just trying to find the correct color paint.
Re: interior paint [Re: 67fastfish] #2512280
06/23/18 07:24 PM
06/23/18 07:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Welcome to the board.
I don't have charts for '67, only '63, '68 & '69. Some years they changed interior codes, sometimes they carried over, and some color codes like black tended to span several years.
Another thing is that there are usually 4-5 different codes for the different surfaces; if your car is original, you can see the variations.
Unless someone can post their '67 info, I'd suggest you shop Ebay for 1967 Plymouth color charts, and make sure the Seller's charts also have the interior info, as some charts don't. Typically DuPont charts are the most complete. Their library is also pretty good for comparing the old #s to their current products.
Look around your area for automotive paint suppliers, or ask a local quality body shop who they're buying from.
Re: interior paint [Re: 67fastfish] #2512287
06/23/18 07:57 PM
06/23/18 07:57 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Get yourself a 67 Plymouth factory Service manual for both chassis and body, they are readily available and will list all paint codes and what components they were used on.
Re: interior paint [Re: T2R9] #2512308
06/23/18 08:50 PM
06/23/18 08:50 PM
Toronto, Canada
Toronto, Canada
I see on the net color chart but not sure if they are for the interior? color code ee1 103040 looks right on what I need just don't know if its correct don't want to go to a supplier and buy the wrong paint also for the dash frame it seems different has textured to it if some ones been through an interior restoration could use some help getting the right products the first time around any help is much apprecated
Re: interior paint [Re: 67fastfish] #2512320
06/23/18 09:32 PM
06/23/18 09:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
E1 is exterior dark blue metallic, so you're looking at an exterior chart.
EE1 was the designation used for top & main color, meaning both the same; that's what you'll see on the fender tag, so it's become kind of an alternate code.
The dash, steering column, and upper windshield garnis was textured, aka "suede" finish lacquer. The plastic defroster duct outlet grilles will more or less match but weren't suede.
That's why I recommended you ask the seller if his chart also lists interior codes; please re-read my reply above. Interior colors are almost always different codes than exterior, except for some UDF (upper door frame) colors.
Re: interior paint [Re: topside] #2512323
06/23/18 10:01 PM
06/23/18 10:01 PM
Toronto, Canada
Toronto, Canada
topside thanks for the info.
Hopefully some other members will have the code I am looking for.
thanks
Re: interior paint [Re: 67fastfish] #2512451
06/24/18 03:58 AM
06/24/18 03:58 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Below is a copy of a 1969 Barracuda (not 1967) factory service manual, chapter 23, Paint Charts, to give you an idea of the information you need and how it is organized. See a 1967 FSM for your correct colors.
INTERIOR COLORS BARRACUDA
EXTERIOR GLOSS FINISH COLORS
Used On: Integral Door Upper and Lower Garnish.
2 Door Hardtop Quarter Panel Lower Garnish.
Black Velvet, Chrysler Code AY 1TX9, Ditzler Code 9000
Bright Blue Metallic, AY2EB5, 2019
Light Bronze Metallic, AY2ET3, 2030
Dark Green Metallic, AY2EF8, 43786
Bright Red, AYlER6, 2029
GLOSS FINISH COLORS
Used On: 2 Door Hardtop Quarter Panel Upper Garnish Moulding.
Fastback Headlining Retainer Moulding.
Lower Wheelhouse Moulding. Rear Quarter Moulding.
Convertible Header and Defogger Intake Bezel.
Jewel Black, Chrysler Code ABlTX9, Ditzler Code 9000
Thunder Blue Metallic, AB2EB5, 13693
Golden Tan Metallic, AY2ET3, 23086
Bayou Green Metallic, AB2EF8, 43926
Rally Red, ABlER6, 71685
LOW GLOSS FINISH COLORS
Jewel Black, AB5TX9 9028 Console Only
Jewel Black (Semi-Gloss), AB3TX9 9293 Optional for Front Seat Manual Adjuster
Majesty Blue, AB5EB9 13686 Console Only
Buckskin Tan, AB5ET8 23061 Console Only
Bayou Green Metallic, AB6EF8 43929 Console Only
Rally Red, AB5ER6 71687 Console Only
SUEDE FINISH COLORS
Used On: Instrument Panel. Glove Box Door. Ash Receiver and Steering Column Assembly.
Jewel Black AC38VX9 9324
Baltic Blue Metallic AC39EB7 13705
Sienna Tan AC38ET8 23076
Bayou Green Metallic AC39EF8 43925
Regatta Red AC38ER8 71688
Re: interior paint [Re: kentj340] #2660748
05/30/19 08:42 PM
05/30/19 08:42 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
I checked my '67 Plymouth FSM (original, paper copy) and I don't see any paint charts like that.
Re: interior paint [Re: kentj340] #2660763
05/30/19 09:32 PM
05/30/19 09:32 PM
USA
rftroy Offline
rftroy  Offline
USA
Go here for free service manuals:
http://www.mymopar.com/index.php?pid=109
And, yes, there are no paint charts in the 1967 Plymouth Service Manual.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: interior paint [Re: rftroy] #2660787
05/30/19 10:34 PM
05/30/19 10:34 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
So that's really no help at all for '67 Plymouth.
I'm looking for the matches for a 'tan' interior, which is a combination of tan, dark brownm and light gold. The dash pad metal & defroster vents looks like a grayish brown suede. It might be tan poly in suede but I'd prefer not to be guessing. The vents need to be replaced and that almost certainly will mean painting.
Re: interior paint [Re: Mattax] #2661307
06/01/19 07:01 PM
06/01/19 07:01 PM
Toronto, Canada
Toronto, Canada
hello all i found the paint codes at auto libary they were under the 1968 interior paint chart that had the codes for 1967 colours for interior
Re: interior paint [Re: 67fastfish] #2661344
06/01/19 08:54 PM
06/01/19 08:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Dash frame colors were typically the darkest (like package trays) of the interior colors, so they'd not reflect light & glare.
The plastic defroster grilles in my '68-'70 B-bodies and '68-'72 A-bodies were/are molded in color and textured, not painted suede, but that would be a better color-match.
Re: interior paint [Re: topside] #2661425
06/02/19 08:07 AM
06/02/19 08:07 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
From my Dupont book.
NMCA NSS 67 Coronet
Re: interior paint [Re: Barry70GTX] #2661429
06/02/19 08:32 AM
06/02/19 08:32 AM
Barry70GTX Offline
Barry70GTX  Offline
From the 67 Service Manual PPG Codes
Gloss top
Suede Bottom
NMCA NSS 67 Coronet
Re: interior paint [Re: Barry70GTX] #2662864
06/05/19 10:18 PM
06/05/19 10:18 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Thanks. Appreciate the additional info from all.
That 67 FSM must be Dodge or Chrysler.
Paint names are different, but presumably the colors are the same and I should be able to figure it out by cross referencing the SS YY names and color codes.
Are the Gloss colors and the Sueded colors in matching order? So a YY interior got 22700 gloss and 22754 Suede?
'67 Plymouth FSM Group 23 is quite different. So maybe I'm missing where such info is, but suspect its not there at all. Maybe in the Parts book instead....
