Sway bar tab pics #2512246
06/23/18 05:20 PM
06/23/18 05:20 PM
ohio
ruderunner Offline OP
ohio
I know this has been asked and posted before, but I can't find it.
Anyone have good pics showing the difference between 66-69 B Body sway bar tabs and 70 B 70-74 E body tabs?
Angry white pureblood male
Re: Sway bar tab pics [Re: ruderunner] #2512282
06/23/18 07:38 PM
06/23/18 07:38 PM
AndyF Offline
AndyF  Offline
Early ones are out near the shock mount, later ones are in the middle of the LCA.
Re: Sway bar tab pics [Re: ruderunner] #2512316
06/23/18 09:28 PM
06/23/18 09:28 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Yes it has.
I have things "bookmarked in the computer"
66-69 LCA's B body Sway Bar Tab 001 (Small).JPGLCA B & E Body Rebuilt 001 (Small).JPG
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Sway bar tab pics [Re: AndyF] #2512346
06/23/18 10:57 PM
06/23/18 10:57 PM
pgh pa
captaindodge Offline
pgh pa
So the question is, if the 69 B-body and the 70 B-body have the same diameter sway bar then is the 70 a stiffer sway bar?
Re: Sway bar tab pics [Re: ruderunner] #2512361
06/23/18 11:13 PM
06/23/18 11:13 PM
ohio
ohio
Shorter arms on the sway bar too but the control arms have more leverage on it.
This is all based on redoing the front brakes on my roadrunner. Did the discotech swap years ago and used the wrong calipers, later style. Figure if I'm replacing calipers might as well get the right ones and mount them correctly. But that means redoing the sway bar.
Re: Sway bar tab pics [Re: ruderunner] #2512579
06/24/18 01:38 PM
06/24/18 01:38 PM
AndyF Offline
AndyF  Offline
On the early B body cars the anti-sway bar mounts to the strut.
Re: Sway bar tab pics [Re: AndyF] #2512699
06/24/18 07:12 PM
06/24/18 07:12 PM
pgh pa
pgh pa
Andy, where can I get an end-link like you show attached to the strut bar?
