Howards EDM lifters #2511940
06/22/18 10:54 PM
06/22/18 10:54 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
My cam and or lifters have worn out and I need to replace them. I had a Comp solid flat cam with Comp lifters and I believe I have a few lobes or lifters gone.
I am going with the EDM lifters and I still haven't decided on a cam yet.
Anyone have any real world experience with the Howard's lifters?
Gus beer
64 Plymouth Savoy
Dana 60
Re: Howards EDM lifters [Re: fourgearsavoy] #2511959
06/22/18 11:21 PM
06/22/18 11:21 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have probably 3000 miles on mine. The first solid cam I ran was a Lunati. I now have the MP 528. I did replace the lifters when switching cams though. I followed the valve lash to the cam card and everything has been great. I do add a bottle of the Comp Cams break in supplement at each oil change though.
Re: Howards EDM lifters [Re: fourgearsavoy] #2511966
06/22/18 11:27 PM
06/22/18 11:27 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I've had a set in my pile for about a year.
My springs are around 180/ 340.
I had the intake off a couple months back, the wear looks normal.
I am running this cam in at 102.
https://www.summitracing.com/parts/hrs-720152-08/overview/
The EDM holes are .016, still holds around 40 PSI hot at 1000 rpm idle.
I was told the holes might bleed off oil pressure, but there's plenty.
Your car (which is way cool BTW) would probably like this cam more than my 4000 lb car with 3.54 gears.
EDIT a couple thousand miles and a bunch of pulls.
Advancing the cam 2 degrees made a noticeable difference on my deal.
Re: Howards EDM lifters [Re: 65Fury440] #2511974
06/22/18 11:38 PM
06/22/18 11:38 PM
Rittman Ohio
Rittman Ohio
That cam sounds like a good choice for my engine and with a 4.10 gear and 4-speed it would probably go real nice.
I was looking at a Lunati Voodoo cam https://www.summitracing.com/oh/parts/lun-30230743/overview/?retaillocation=oh
I think the cam you listed might be a better choice with my Indy head stroker thumbs
Gus beer
64 Plymouth Savoy
Dana 60
Re: Howards EDM lifters [Re: fourgearsavoy] #2512874
06/25/18 02:40 AM
06/25/18 02:40 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Gus I use the Comp EDM lifters that Dwayne Porter got me with the flat tappet cam he ground for my eng. They have been in my eng since June 2011 when I first fired it up. And they are still going strong as I just had my 63 out today and she is running as good as ever. Ron
Re: Howards EDM lifters [Re: fourgearsavoy] #2512877
06/25/18 02:58 AM
06/25/18 02:58 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
I've got the Comp EDM solid lifters in my stroker B motor going on five years now. Probably 3000 miles ... Comp 0.550 solid cam. AMSOIL Z-Rod 10W-30 Oil. Broken in on single springs and added the inners later. No issues - knock wood! I figure that the EDM lifter face is just a little extra insurance against flattening a lobe or two.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Howards EDM lifters [Re: rumblefish72] #2512986
06/25/18 01:00 PM
06/25/18 01:00 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I did the same and broke my cam in on just the outer springs. My cam is .585 & .592 lift with 264 & 270 @ .050. Ron
