Fuel pump pushrod still needed when removing fuel pump ? #2511788
06/22/18 03:52 PM
06/22/18 03:52 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Is the pushrod still needed when removing the fuel pump ? Assuming not having one installed would create an internal oil leak.
Re: Fuel pump pushrod still needed when removing fuel pump ? [Re: varunner] #2511791
06/22/18 03:58 PM
06/22/18 03:58 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
No.That and its not necessary to remove it as it just drops down against the block off plate.IIRC no oil loss if removed.Rocky
Chrysler Firepower
Re: Fuel pump pushrod still needed when removing fuel pump ? [Re: varunner] #2511793
06/22/18 03:59 PM
06/22/18 03:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Loose it...
Re: Fuel pump pushrod still needed when removing fuel pump ? [Re: varunner] #2511809
06/22/18 04:36 PM
06/22/18 04:36 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
New drift punch.
Re: Fuel pump pushrod still needed when removing fuel pump ? [Re: varunner] #2511825
06/22/18 05:21 PM
06/22/18 05:21 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
If the ends are still in good shape, don't ever toss a good OEM B/RB pushrod. Somebody needs it. Parts to exact proper OE specs have not been made or sold within (at least) the past 10 years...probably longer than that. An investigation and a few unfortunate hurt feelings went into that statement.
Rich H.
Esse Quam Videri
Re: Fuel pump pushrod still needed when removing fuel pump ? [Re: varunner] #2511850
06/22/18 06:16 PM
06/22/18 06:16 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
thanks. so I've one if anyone needs one, looks pretty worn though. it does look like a good size for punch.
