Lifter tick and oil through pushrods #2511436
06/21/18 06:26 PM
06/21/18 06:26 PM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
I have a 383/432 stroker with Hughes retrofit hydraulic roller lifters (morel). I have had some lifter tick from day one that seems to be getting more noticeable. My push rods have holes to allow from push rod oiling, which I do not need, and I’m now wondering if i could be bleeding off some pressure at the lifters causing the tick. I have 3/4 of a turn preload and am using a high volume oils pump. Pressure is 45-50 hot at cruise and I have used different viscosities of oil with no noticeable improvement. Currently 10w 30 mobile 1 synthetic.
Thoughts?
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: Lifter tick and oil through pushrods [Re: Fishmarket] #2511461
06/21/18 07:26 PM
06/21/18 07:26 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
try another 1/4 turn down, that made my Hughes [Morel] lifter a little quieter. the push rod oil has nothing to do with it.
Re: Lifter tick and oil through pushrods [Re: CSK] #2511609
06/22/18 03:33 AM
06/22/18 03:33 AM
Essex, Ont., Canada
Essex, Ont., Canada
My theory was that the extra oil travelling through the pushrods possibly was reducing the internal pressure at the lifter plunger causing the lifter to bleed down quicker.
Re: Lifter tick and oil through pushrods [Re: Fishmarket] #2511615
06/22/18 04:19 AM
06/22/18 04:19 AM
Probably not, unless those lifters are designed for pushrod oiling like AMC lifters are work
Re: Lifter tick and oil through pushrods [Re: Fishmarket] #2511720
06/22/18 01:09 PM
06/22/18 01:09 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
They are AMC type lifters
