Painting a chrome 2003 Dodge truck grill frame #2511512
06/21/18 10:26 PM
06/21/18 10:26 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Looking for some advice from painters that have painted a plastic chrome grill frame. Should the chrome be striped off the grill, and if so whats the best method, or can I just scotch brite it and go from there. Working on a 2003 dodge truck grill.
Thanks!
Dan.
Re: Painting a chrome 2003 Dodge truck grill frame [Re: mopar4ya] #2511517
06/21/18 10:34 PM
06/21/18 10:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A new black grille and frame from Rockauto is $55
https://www.rockauto.com/en/moreinfo.php?pk=2158440&cc=1413425&jsn=493
That would be easier than stripping the chrome
Don't be the exception.
Re: Painting a chrome 2003 Dodge truck grill frame [Re: mopar4ya] #2511521
06/21/18 10:39 PM
06/21/18 10:39 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The chrome plating sometimes wrinkles up. I suspect you could peel it off if you can cut a small hole on an edge and carefully scrape it all off. Being in direct sunlight will help.
Me? I'd get a new one.
Re: Painting a chrome 2003 Dodge truck grill frame [Re: Kern Dog] #2511533
06/21/18 11:05 PM
06/21/18 11:05 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
scuff it by hand with 80 grit,epoxy prime it,let it dry then scuff it again with a maroon scotch brite and paint it.
Re: Painting a chrome 2003 Dodge truck grill frame [Re: mopar4ya] #2511645
06/22/18 10:03 AM
06/22/18 10:03 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
stripping off the chrome works best. if you don't the paint will eventually peel.
the best way without stripping the chrome is lightly etch the chrome with a sandblaster, etch prime, epoxy prime, them paint.
next best is scotch with red scotch brite, etch, epoxy, paint.
when i say etch prime use a 2 part primer. etch in a spray bomb is useless in this situation.
some people say etch primer isn't required because epoxy has etching qualities. yes it does but 2K etch primer will allow the acid to bite in MUCH better than just epoxy ever will. when painting over chrome you want the max adhesion or it will eventually peel no matter what you do.
someone posted about a black grill on the cheap.
in my opinion buying and painting this is probably your best bet
perception is 90% of reality
Re: Painting a chrome 2003 Dodge truck grill frame [Re: Mr T2U] #2512273
06/23/18 06:56 PM
06/23/18 06:56 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Thanks everyone. I believe I am going to try and strip it and see what happens. Don't have anything invested, so if I ruin it I'm not out much. Is there a chemical that works well to do this?
Re: Painting a chrome 2003 Dodge truck grill frame [Re: mopar4ya] #2512278
06/23/18 07:12 PM
06/23/18 07:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Elbow grease. grin
Re: Painting a chrome 2003 Dodge truck grill frame [Re: stumpy] #2512304
06/23/18 08:46 PM
06/23/18 08:46 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Originally Posted By stumpy
Elbow grease. grin
See on line a few say super clean or a toilet cleaner gell will work. Just wondered what has worked the best for anyone else.
Thanks!
