Low Oil Pressure #2509783
06/17/18 11:06 PM
06/17/18 11:06 PM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
Took the Scamp for a drive and the oil pressure was dropping to zero on the gauge at idle, rpms up it increases but still low. Changed to different headers and wondering if the header too close to the oil filter could create such a drastic change. The Hedmans are a bit closer than the TTI's were to the filter, no other changes except different mufflers. Motor was only running for about 10 minutes max, oil level full and about 85* outside
Thoughts?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Low Oil Pressure [Re: Stroker Scamp] #2509789
06/17/18 11:15 PM
06/17/18 11:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
First step try a new gage then maybe screw on a new filter so you can cut that one apart and inspect for anything that shouldn’t be there.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Low Oil Pressure [Re: pittsburghracer] #2509814
06/18/18 12:43 AM
06/18/18 12:43 AM
iagree scope
You probably didn't run it long enough to get the oil temps up above 220 F so I don't think the oil temps. are a player now shruggy
Re: Low Oil Pressure [Re: Cab_Burge] #2511036
06/20/18 08:51 PM
06/20/18 08:51 PM
pacific northwest
pacific northwest
Update, tried new gauge no pressure, took filter off and cranked the motor over nothing from the filter as far as pressure
What to check next?
1. oil drive shaft stripped?
2, drop the pan and new pump?
any way to bench test a pump? Any else you can think of Im all ears
Re: Low Oil Pressure [Re: Stroker Scamp] #2511040
06/20/18 09:00 PM
06/20/18 09:00 PM
PA.
"Little"John
"Little"John
PA.
Common on chevies but rare on mopars but you may have to drop the pan to check the oil pickup. How did the oil filter look as far as contamination. Good, bad. If bad it has to come apart anyway. If it’s a pump at least they are pretty cheap. If it’s bearings, not so much.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Low Oil Pressure [Re: pittsburghracer] #2511042
06/20/18 09:01 PM
06/20/18 09:01 PM
PA.
"Little"John
"Little"John
PA.
Sounds like you should pull the distributor and try a priming tool and a drill
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Low Oil Pressure [Re: pittsburghracer] #2511086
06/20/18 10:33 PM
06/20/18 10:33 PM
pacific northwest
pacific northwest
Filter looked good so I put it back on, pulled distr. and primed with a drill, had to rev drill pretty good but have pressure at gauge and to the rockers. If I remember correctly I have a 10-30 weight oil where I usually run the 20-50 Valvoline race oil (they were out)
can the change in viscosity make that big of a difference?
or possibly oil pump getting weak?
Re: Low Oil Pressure [Re: Stroker Scamp] #2511103
06/20/18 10:53 PM
06/20/18 10:53 PM
PA.
"Little"John
"Little"John
PA.
Just curious but what kind of filter. And yes viscosity can affect it but also remember the drill rpm doesn’t duplicate engine rpm. Years ago I ran 40 weight, then 30, then 10-40, now 10-30. With the RacePak I can closely watch what is going on during a pass and in the pits.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Low Oil Pressure [Re: pittsburghracer] #2511123
06/20/18 11:28 PM
06/20/18 11:28 PM
pacific northwest
pacific northwest
I run a Napa Gold and always have, going to put the Valvoline back in and change filter one at a time to see whats up. Thanks for the tips
Re: Low Oil Pressure [Re: Stroker Scamp] #2511125
06/20/18 11:33 PM
06/20/18 11:33 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
He already took the filter off the block and cranked it to find no oil coming out of block. What does the filter have to do with anything? Waste of time and money to try a different filter at this point.
[image][/image]
Re: Low Oil Pressure [Re: sgcuda] #2511127
06/20/18 11:36 PM
06/20/18 11:36 PM
PA.
"Little"John
"Little"John
PA.
Read his post above. He has oil pressure now but it’s not as high
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Low Oil Pressure [Re: Stroker Scamp] #2511128
06/20/18 11:38 PM
06/20/18 11:38 PM
PA.
"Little"John
"Little"John
PA.
No problem I hope all turns out well for you
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Low Oil Pressure [Re: Stroker Scamp] #2511140
06/21/18 12:04 AM
06/21/18 12:04 AM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Going from 20-50 to 10-30 will make a difference. But not a 30-40 PSI difference. I use a 1/2 drill and 2 hands to spin the pump with authority while priming. If you're spinning the pump easily with a 3/8, something's fishy. Wide open with an 800 RPM 1/2 drill should get 60-70 PSI and running the drill slow maybe 30. If not, I would try another filter for the heck of it before looking deeper.
Re: Low Oil Pressure [Re: Stroker Scamp] #2511147
06/21/18 12:23 AM
06/21/18 12:23 AM
how much pressure?
Re: Low Oil Pressure [Re: RapidRobert] #2511172
06/21/18 01:53 AM
06/21/18 01:53 AM
pacific northwest
pacific northwest
went back to original gauge and primed with a 3/8 drill 68 psi,
so something made the gauge drop to zero, the hunt is on.
will let you know what I find
Re: Low Oil Pressure [Re: Stroker Scamp] #2511175
06/21/18 01:59 AM
06/21/18 01:59 AM
Maybe some tiny bit of debris in the bypass valve in the pump making it stick open when it acted up hot? work
I've seen that more than once in BB, they are a lot easier to check also shruggy
Good luck, you will find it up
Re: Low Oil Pressure [Re: Cab_Burge] #2511188
06/21/18 02:11 AM
06/21/18 02:11 AM
PA.
"Little"John
"Little"John
PA.
If you tried this the first time right after changing the oil sometimes it takes a little longer to pick up pressure
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Low Oil Pressure [Re: pittsburghracer] #2575180
11/07/18 03:10 AM
11/07/18 03:10 AM
pacific northwest
pacific northwest
Finally had a chance to get out to the shop (house remodel)
pulled the filter and cut it open, no metal
Drained the oil and going to let it set overnight covered
so I can inspect tomorrow, looked pretty good so far
think I will try another filter and the 20-50 Valvoline
oil I normally run and see what happens. I will update my findings
and thanks for the advice
Re: Low Oil Pressure [Re: Stroker Scamp] #2575304
11/07/18 01:44 PM
11/07/18 01:44 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Sounds like you left a plug out somewhere.
Re: Low Oil Pressure [Re: Stroker Scamp] #2575347
11/07/18 03:09 PM
11/07/18 03:09 PM
crabman173
crabman173
Kink in oil pressure line? While doing the headers? Copper or nylon easy to damage
