My Thumper inspired dominator.... #2510203
06/18/18 11:03 PM
06/18/18 11:03 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
worked flawless in it's first time out at dragway 42 this weekend,had it hooked up to the wide band and it is running leaner than the 3 circuit did by a good margin but still appears to be a little fat right after the starting line hit and all the way down track with the wide band showing in the 11.5 range, need to get it in the 13.0to13.5 range, bumping the high speed bleed from a 26 to a 28 helped so I am going to drop the main jettingand the PVCR a few numbers and go out to the local track and give it another test session in the next few weeks so I can be ready for Monster Mopar at Norwalk next month, thanks Dom I think it just a few steps away from total success, next is toss the 3 circuit to 2 circuit conversion carb on and dial it in too, up
Re: My Thumper inspired dominator.... [Re: dartman366] #2510216
06/18/18 11:33 PM
06/18/18 11:33 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Dominic seems to be getting pretty good at this stuff.
[image][/image]
Re: My Thumper inspired dominator.... [Re: dartman366] #2510261
06/19/18 02:02 AM
06/19/18 02:02 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Cool man and great news and ya, I'd rather be 11.5 than thumbs 15.5 for sure and it WILL start to shine when leaned out............
Re: My Thumper inspired dominator.... [Re: dartman366] #2510297
06/19/18 09:08 AM
06/19/18 09:08 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Do not chase Air Fuel Numbers!! Go by what the engine tells you when it's happy. The Air Fuel Number is just for reference for when you find the best performance tune.
Re: My Thumper inspired dominator.... [Re: STEFF] #2510372
06/19/18 01:42 PM
06/19/18 01:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly, a directional tuning aid then it is what it is BUT, without one you never REALLY know where you're at and they are eye opening when tuning the 4 circuits on the street........idle, transition, cruise and WFO............ thumbs
Re: My Thumper inspired dominator.... [Re: dartman366] #2510373
06/19/18 01:42 PM
06/19/18 01:42 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What Steff said. Don't chase AFR chase ET and MPH AFR is just a reference/target once you get to the best ET and MPH. One issue I see all the time helping people with racepacks is they are chasing the "ideal" number for a given channel, ignoring what the time slip says. MPH is still the barometer to measure by. There is NO "magic number" to chase. Every combo will want something different, even different fuels have different stioch numbers. FWIW if the heads up car was at 11.5 it would be pretty damn close for us where is makes max power/best MPH. Just one example.
AS for being fat at the hit its pretty typical, especially in a car with a brake. Even foot braking you have the pump shot that will spike it fat at the hit, its not unusual. You can help that by adding timing at the hit to help burn that excess fuel. But chase numbers on the slip not numbers on a gauge!
Re: My Thumper inspired dominator.... [Re: Al_Alguire] #2510395
06/19/18 02:30 PM
06/19/18 02:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So true about the fuels and different needs then the mods to the carb(s) to get the curve set as needed..........fun chit........... thumbs
Re: My Thumper inspired dominator.... [Re: Thumperdart] #2510490
06/19/18 07:32 PM
06/19/18 07:32 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I know the wide band is a tuning aid and is not a end all be all iron clad deal, but by using it I can make changes and see what it does and how the car reacts to it by watching the time slip's also, if by leaning it out some and it slow's or mph drops down,then I know I went the wrong way and it actually likes a little more fuel than I thought,and vise versa, I did pull a plug and they have colored some but it is a lighter grey than ever before and the collectors are lighter in color than before so to me that is a plus, the biggest thing I was happy about, was with Dom's help and guidence I never had the first hiccup, that just made my job even easier because I am not chasing a gremlin while trying to find the tune. up
Re: My Thumper inspired dominator.... [Re: dartman366] #2510509
06/19/18 08:34 PM
06/19/18 08:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thank you sir and do what YOU want and get the results that get you the best time slip from the 60 on out......... beer
Re: My Thumper inspired dominator.... [Re: Al_Alguire] #2510551
06/19/18 10:32 PM
06/19/18 10:32 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Al, the numbers so far are just a baseline to get things going, every individual motor has it's own "ideal" number and I am just starting the process of finding mine but I will be using "time slip tuning" as my primary information, my next purchase will be a weather station to help keep track of the conditions up
Re: My Thumper inspired dominator.... [Re: dartman366] #2510606
06/20/18 12:21 AM
06/20/18 12:21 AM
Time slip,(use all of the measurements) spark plug and weather stations are your friend, especially on jetting, timing and spark plug heat range scope
Re: My Thumper inspired dominator.... [Re: dartman366] #2510824
06/20/18 02:17 PM
06/20/18 02:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Data is always your friend. But don't look passed the basics as well. I see it all the time helping people who are more worried about what the racepack says rather than listening to what the car is telling them. That was my point.
Re: My Thumper inspired dominator.... [Re: Al_Alguire] #2510874
06/20/18 03:56 PM
06/20/18 03:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Couldn't agree more and I too am guilty as charged........ biggrin
Re: My Thumper inspired dominator.... [Re: Al_Alguire] #2510876
06/20/18 04:00 PM
06/20/18 04:00 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I would guess every carb was phat at Quaker City this weekend since the air was rarely below 3000ft. We saw 3900 on Sunday.
If you have a smart phone try Dr. Dial-In from the appstore. You can lookup the tracks closest airport weather station and use that. Its pretty darn accurate. I hope I don't regret sharing my super secret tips.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: My Thumper inspired dominator.... [Re: 69dart] #2510907
06/20/18 04:55 PM
06/20/18 04:55 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Google is your friend. A number of density altitude calculators on the web for free. All you need is your tracks altitude and use current conditions from the nearest Accuweather site.
Humidity, temp, baronetric pressure. All those figures show up when you hit current conditions on Accuweather.
Use it all the time.... one i use is dragtimes. Quick and easy
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: My Thumper inspired dominator.... [Re: 69dart] #2511068
06/20/18 10:06 PM
06/20/18 10:06 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
And the way I was sweating my butt off I was feeling pretty phat my darned self, lol,, and yes Sunday was by far the worse.
