Wrinkle finish paint #2509474
06/17/18 12:44 AM
06/17/18 12:44 AM
Minnesota
TrackPack Offline OP
Minnesota
What is the best wrinkle finish paint for restoring 69 road runner air cleaner?
Re: Wrinkle finish paint [Re: TrackPack] #2509503
06/17/18 02:08 AM
06/17/18 02:08 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
When this question pops up, a lot of people suggest powder coat. It's the most durable and the finish comes out even across the entire piece. The size of the wrinkles is a little different then stock though...as per the posts I've read.
There are several wrinkle paint brands on the market. I used VHT on my Challenger heater bezels. I think they turned out really nice. I've heard good things about the Harley Davidson brand of wrinkle paint as well.
Re: Wrinkle finish paint [Re: TrackPack] #2509543
06/17/18 10:36 AM
06/17/18 10:36 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I recently used the Seymour brand wrinkle. I like the results. It does take a long time to wrinkle on its own. I ended up using a heat gun to help it along.
Re: Wrinkle finish paint [Re: TrackPack] #2509680
06/17/18 06:08 PM
06/17/18 06:08 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I lay down a base coat of regular black, then the wrinkle over that, and use a heat gun. The original ones had inconsistent texture, by the way. VHT is decent.
Re: Wrinkle finish paint [Re: TrackPack] #2509702
06/17/18 07:19 PM
06/17/18 07:19 PM
Minnesota
Minnesota
Thanks everyone. VHT is the only one that I knew about so I'll go with that.
Re: Wrinkle finish paint [Re: TrackPack] #2509745
06/17/18 09:48 PM
06/17/18 09:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Probably easiest to find @ most auto parts stores. Eastwood also sells a wrinkle finish.
Re: Wrinkle finish paint [Re: TrackPack] #2509836
06/18/18 03:09 AM
06/18/18 03:09 AM
People's Republic of Kali
70runner Offline
70runner  Offline
Done it both ways, powder coat and spray bomb. Powder coat (below) came out the nicest. Spray bomb will work, but practice on something before you engage the cleaner.
Re: Wrinkle finish paint [Re: 70runner] #2509984
06/18/18 01:49 PM
06/18/18 01:49 PM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
great job!
B5 Challenger T/A
Re: Wrinkle finish paint [Re: TrackPack] #2510012
06/18/18 02:41 PM
06/18/18 02:41 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
what do the OE resto places use? when in doubt ask them.
Super Commando
Re: Wrinkle finish paint [Re: TrackPack] #2510059
06/18/18 05:05 PM
06/18/18 05:05 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Powder Coat on the Air Cleaner - Perfection , I was like WOW
$75.00 had it a week later local
VHT on the Valve Covers as I was in a hurry and didn’t want to wait for turn around time on a new motor
More inconsistent, heat gun or direct sun really helps - Pretty durable so far
Directions say you can use an oven for final cure or the heat of the motor also
Leave a few days for handling time
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Wrinkle finish paint [Re: TrackPack] #2510060
06/18/18 05:06 PM
06/18/18 05:06 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Weird
Pictures show up on Windows
But not on IPad
Notice that a lot in threads ?
Siberian Huskies
Re: Wrinkle finish paint [Re: TrackPack] #2510072
06/18/18 05:53 PM
06/18/18 05:53 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I heat the piece to 170 degrees in an kitchen ovens lowest setting prior to spraying.
Then spray VHT can and back in oven to 300 deg 20 min.
Very consistent. I can file my nails on the wrinkle. The baked paint is very durable.
Re: Wrinkle finish paint [Re: TrackPack] #2510091
06/18/18 06:40 PM
06/18/18 06:40 PM
Minnesota
Minnesota
Beautiful examples...hope mine turns out as well.
Re: Wrinkle finish paint [Re: TrackPack] #2510265
06/19/18 02:06 AM
06/19/18 02:06 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You are not married, are you Steve...?
OR you have an oven in your garage ?
Re: Wrinkle finish paint [Re: Kern Dog] #2510320
06/19/18 10:44 AM
06/19/18 10:44 AM
New York
rarefish Offline
rarefish  Offline
New York
iagree
I pulled that stunt once, The kitchen smelled like a paint booth for a couple of hours. It did not go over too good with the wife...
Re: Wrinkle finish paint [Re: rarefish] #2511898
06/22/18 08:55 PM
06/22/18 08:55 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Do that to an intake manifold...and when the smoke starts rolling out remember that you didn't take the heat shield off.
