Re: I beam or H beam
[Re: DusterKid]
#2509939
06/18/18 12:31 PM
06/18/18 12:31 PM
Posts: 1,965 Apollo, PA.
B1MAXX
Apollo, PA.
Just my opinion: oem/aftermarket I beam.....ok for mild performance build. h-beam.....great high performance rod, would guess its in 90% of all 9-10 second bracket race style engines. Billet (steel/aluminum/titanium)I beam...best in my opinion for builds beyond that 9-10 second range. When I think of a race 11.5 to 1, 408 build, me thinks of a 4340 crank and h-beams. no science , all gut here.
[Re: DusterKid]
#2509979
06/18/18 01:36 PM
06/18/18 01:36 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
Are you wanting SB stock type rod and wrist pin end rods? If so either one will work I'm going to build a old time offset stroker 360 motor cast crank with SB Chevy 2.00 rod journal sizes and probably use a set of Speedway 6.125 long small journal Chevy I beam rods Lots of choices when starting a new build, take your time and check out every choice out there before deciding
[Re: DusterKid]
#2510175
06/18/18 10:01 PM
06/18/18 10:01 PM
Posts: 4,206 New York
polyspheric
New York
H is obviously stronger, which is why almost no OEM use them.
Boffin Emeritus
[Re: lewtot184]
#2510202
06/18/18 11:02 PM
06/18/18 11:02 PM
Posts: 1,176 East Coast
A/MP
East Coast
in my opinion, the lower the rod angle the more likely i'd choose an h-beam rod. I think the weak link will be the main caps. I always use Pro Gram main blocks and studs for any SB over 6700. There's a lot of walking going as the motor revs.
[Re: polyspheric]
#2510210
06/18/18 11:20 PM
06/18/18 11:20 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Either shaped rod will be fine. Pick one that's rated for your intended use (which comes down to cross section), and don't worry so much about the shape. I wouldn't be worried to use the Scat I-beams at all on your build. H is obviously stronger, which is why almost no OEM use them. Actually it's not strength related at all... it's the manufacturing cost/ease that pushes us (FCA) towards powder metal I-beams more then anything. Since the big/small ends are in the same direction as the I-shape, they can be easily formed, and VERY close to final shape which minimizes the machining costs. Even the hellcat rods are formed this way. https://www.youtube.com/watch?v=azGg68B-Glk
[Re: DusterKid]
#2510257
06/19/18 01:46 AM
06/19/18 01:46 AM
polyspheric
New York
NO, really? Should I have used the [sarc] tag?
Boffin Emeritus
[Re: DusterKid]
#2510258
06/19/18 01:47 AM
06/19/18 01:47 AM
polyspheric
New York
Widmer made some very interesting comments w/r/t beam shape 20 years ago specifically where in the power stroke gas pressure spikes, different between NA and turbo...
Boffin Emeritus
[Re: DusterKid]
#2510270
06/19/18 02:37 AM
06/19/18 02:37 AM
Posts: 30,995 Oregon
AndyF
Dad wants to build a 360 stroked to 408. Will be an all out race motor, but on the milder side. 11.5:1, won't be spun past 6500 and will have around a 600 lift solid cam. At what point do you guys start using an H beam rod over I beam? At a certain rpm, higher compression? SCAT I beam rods will work just fine in your combination. I used the SCAT I beam rods in my 470/240 engine which makes 700 hp at 7000 rpm. I have over 100 dyno pulls on that engine and now it is going into the Duster for some drag racing. Here is a picture of the rotating assembly in that 470. I used a superlight SCAT crank, the I beam rods and some custom pistons.
[Re: DusterKid]
#2510480
06/19/18 07:12 PM
06/19/18 07:12 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Got a 360 stroked to 408 with scat 4340 I beams..nothing to grind...lighter weight...shifts at 6500..traps 6900.
Got a 2nd 408 ready to go in another car same set up..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
