BIGBLOCK PLUG WIRES #2509344
06/16/18 03:01 PM
06/16/18 03:01 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Who carries the best fitting, most original looking, proper ignition wires for a 400 engine. Looking for ones with the 90 degree plug boots where they should be. Bought a set from Mancini and they're horrible frown
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2509387
06/16/18 05:19 PM
06/16/18 05:19 PM
would it work to add some correct 90 deg boots (new or used) from another set?
Re: BIGBLOCK PLUG WIRES [Re: RapidRobert] #2509398
06/16/18 06:24 PM
06/16/18 06:24 PM
S.E.Ohio
S.E.Ohio
Tried that, but the wires were marginally long enough. I want wires that fit right.
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2509539
06/17/18 10:24 AM
06/17/18 10:24 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Firecore got every plug boots you need BUT the 135° ones when I ordered my second set, which are used on 8 and 1 plugs as far I recall?. ( I'm sure at least the 8th ). Since they didn't have the 135° degrees boots offered to install 90° but I told them didn't install any, because I could reinstall the ones I have on my running set
I sent them the CORRECT measures for 73 and lates setup, WHICH IS A DIFF LENGHT SET than pre 72s
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2509541
06/17/18 10:31 AM
06/17/18 10:31 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
another option, get NOS ones, which uses to run into $50-80 rate on ebay. I got a set JUST to get the correct lenghts to make the Firecore250 ones.
( made a search and didn't float one at this moment... I know PN is something like 388xxxx )
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2509666
06/17/18 04:59 PM
06/17/18 04:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the best way is to get the crimping tool/pliers and components and make your own. I've been doing this since the early '70's. it's not difficult and everything fits; the first time.
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2509703
06/17/18 07:25 PM
06/17/18 07:25 PM
S.E.Ohio
S.E.Ohio
I just put the old ones back on. They weren't that old, just didn't like the Accel ones. I wanted more original looking.
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2510725
06/20/18 11:29 AM
06/20/18 11:29 AM
crlush Offline
crlush  Offline
I buy the Taylor brand that you have to crimp the distributor ends on, they have different colors and you can remove the lettering with some laquer thinner or enamel reducer.
Re: BIGBLOCK PLUG WIRES [Re: crlush] #2510850
06/20/18 03:11 PM
06/20/18 03:11 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Good info. Thank you! thumbs
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2511044
06/20/18 09:02 PM
06/20/18 09:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have used Taylor wires and they worked fine for me for many years. But I have to admit these Firecore wires I have on my eng now fit great and work very good. And they fit perfect with the angle plug EZ heads. So both Firecore and Taylor have worked good for me. Ron
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2511227
06/21/18 09:55 AM
06/21/18 09:55 AM
an8sec70cuda Offline
I prefer a set that I can cut and fit myself. Can't do that with Firecore since they only sell pre-made sets. Taylor or MSD for me. There is no magic in plug wires, or any ignition component for that matter, no matter what their best sales gimmick is. I've tried them on the dyno and at the track...as long as your wires are in good condition, they work fine.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: BIGBLOCK PLUG WIRES [Re: an8sec70cuda] #2511251
06/21/18 10:43 AM
06/21/18 10:43 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
sounds like me! I buy either taylor or msd bulk with boots and connectors and make it. people can change their oil so why is crimping a couple of connectors on a wire rocket science?
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2511254
06/21/18 11:08 AM
06/21/18 11:08 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Just found the measures I provided to customwires ( firecore ), measured per customwires specs, from center of terminal to center of terminal. Measured the NOS set I got to get the firecore set correctly done
Coil---9"
1-----22 1/4"----90º boot ( cilinder 2 )
2-----25----90º boot ( cilinder 4 )
3-----31 1/4"----90º boot ( cilinder 6 )
4-----40 1/2"----135º boot ( cilinder 8 )
5-----43 3/4" ---- 90º boot ( cilinder 1 )
6-----48" 1/2" ---- 90º boot ( cilinder 3 )
7-----55 3/4"----90º boot ( cilinder 5 )
8-----56 1/2"----135º boot ( cilinder 7 )
This is to use the stock wire brackets ( which need to be trimmed a bit to accept 8 mm wires )
Re: BIGBLOCK PLUG WIRES [Re: NachoRT74] #2511303
06/21/18 01:20 PM
06/21/18 01:20 PM
S.E.Ohio
S.E.Ohio
Coil---9"
THANK YOU!!
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2511747
06/22/18 02:13 PM
06/22/18 02:13 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Sorry,hello, we are out of town, with very limited internet access, until next Wed. We can certainly get your order going when we return, thank you.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: BIGBLOCK PLUG WIRES [Re: sunroofgtx] #2511802
06/22/18 04:15 PM
06/22/18 04:15 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Different year 400's used different lengths due to how they ran and different tabs on valve covers. I see later 400 wires on E-Bay often.
Ron
Re: BIGBLOCK PLUG WIRES [Re: RJS] #2511865
06/22/18 06:53 PM
06/22/18 06:53 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Ron
usually the diff is between pre72 and post73. I got the 73 and lates being my car 74, and those are the measurements I provided.
Re: BIGBLOCK PLUG WIRES [Re: NachoRT74] #2512060
06/23/18 08:43 AM
06/23/18 08:43 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Firecore wires will outperform any plug wire out there. There are numerous people like me who have installed the wires on perfectly tuned hp engines that ran so much better the idle alone picked up 25 to 50 rpms. Back to back testing of new MSD vs Firecore and Firecore kicked butt. So go ahead use those other wires
help
PS thank you Rick! drive
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2513392
06/26/18 10:15 AM
06/26/18 10:15 AM
S.E.Ohio
S.E.Ohio
Re-installed the old ones till this fall. Ran fine. So, Rick I'll be ordering some from you. Maybe see you at a show?
Re: BIGBLOCK PLUG WIRES [Re: Magnumguy] #2514759
06/29/18 02:15 AM
06/29/18 02:15 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Nacho, would you like to order? We are back? Thanks.. 866-973-9473.. Thanks..Thank you (Dilbert)!
