Re: Cut-to-fit axle shafts: How to measure?
[Re: General 68]
#2509822
06/18/18 12:56 AM
06/18/18 12:56 AM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
So you have cut to fit axles and still use taper roller bearings? Your life would be much easier with new style radial ball bearings and snap ring retainer plates Let the flaming begin about the life span of ball bearings Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
