big brake kits for 83 dodge short box #2508290
06/14/18 10:03 AM
06/14/18 10:03 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Is there any kits out there for this truck.
I've heard that this truck uses C body spindles. Is this true?
Matt
Re: big brake kits for 83 dodge short box [Re: MattW] #2508296
06/14/18 10:19 AM
06/14/18 10:19 AM
scratchnfotraction Offline
you can use a 76 new Yorker rotor/bearings/caliper on a 83 truck as it is still the small wheel bolt circle.
cant say on the spindle?
if it had 10" drums in rear you can up those to 11"x2.5" and a HD 12"x3"
or disc brakes for the rear.
I have no issues in my 88 440 truck with stock manual brakes 11x2.5 rear drums.
Re: big brake kits for 83 dodge short box [Re: MattW] #2508607
06/14/18 11:01 PM
06/14/18 11:01 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Welcome to the world of old Dodge trucks! You can't just open a catalog and your wallet to get what you want.
That said, the stock brakes in good condition are fine for commuting and light hauling. What's your goal?
BTW, the 12" brakes are for 8 lug rear ends only. The hub is almost 4.5" in diameter, no room for the small lug pattern, even the 5*5.5" pattern doesn't clear.
Angry white pureblood male
Re: big brake kits for 83 dodge short box [Re: ruderunner] #2509319
06/16/18 01:23 PM
06/16/18 01:23 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Autocross track time
They offer a bolt on kit for the wilwood D52 caliper.
So it will be the 11.75 stock rotor for now and couple that with a good size rear disk.
It will need to be set up correctly.
I'm hoping for less than 3500 lbs
Down the road I'll look into making some hubs and radial caliper mounts.
Matt
Re: big brake kits for 83 dodge short box [Re: MattW] #2509444
06/16/18 10:12 PM
06/16/18 10:12 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I am interested in a caliper bracket as well. Our trucks share the 1.25 rotor width with the viper front rotor. Doesn't seem it would be too hard to fashion a bracket to fit.
Re: big brake kits for 83 dodge short box [Re: MattW] #2509446
06/16/18 10:14 PM
06/16/18 10:14 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Ebooger has a bucks down how to article in this months rag. Uses Jeep Liberty rear rotors/parking brake on and 8 3/4. Looks to be pretty simple and the part I like best- easy on the wallet.
Re: big brake kits for 83 dodge short box [Re: mgoblue9798] #2509465
06/16/18 11:41 PM
06/16/18 11:41 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Google "Industrial chassis inc"
They have a bracket to mount the D52 caliper to our spindles.
Re: big brake kits for 83 dodge short box [Re: MattW] #2509517
06/17/18 06:46 AM
06/17/18 06:46 AM
Guitar Jones Offline
I don't know how you can find anything on that site.
Re: big brake kits for 83 dodge short box [Re: Guitar Jones] #2509594
06/17/18 01:32 PM
06/17/18 01:32 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Lol
Hit home then scroll down until you get to the adapters.
It actually has some good info.
