Re: Where to get street hemi orange engine paint [Re: rickseeman] #2507174
06/11/18 05:37 PM
06/11/18 05:37 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I use Bill Hirsch paints...
www.hirschauto.com
JB Rhinehart, Realist
A-Body's RULE!
Re: Where to get street hemi orange engine paint [Re: ScottSmith_Harms] #2507331
06/11/18 11:53 PM
06/11/18 11:53 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Originally Posted By ScottSmith_Harms
How I prepped it was simple, SUPER clean metal using acetone and phosphoric acid wash to clean the iron. No primer, painted with a gun following Frank's instructions. Laid down nice and hasn't chipped or peeled in the least in 3 years.
Nice job on your 340 Scott up
Plymouth Makes It!
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2507515
06/12/18 01:51 PM
06/12/18 01:51 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
PPG 3116 (Chrysler Mandarin Orange)
At your local PPG dealer.
Rich H.
Esse Quam Videri
Re: Where to get street hemi orange engine paint [Re: ZIPPY] #2507536
06/12/18 03:13 PM
06/12/18 03:13 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Not correct shade.
Re: Where to get street hemi orange engine paint [Re: John_Kunkel] #2507547
06/12/18 03:41 PM
06/12/18 03:41 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Originally Posted By John_Kunkel
Originally Posted By PAULS_340
PPG doesn't have that color, so who might mix a pint of the correct color?
Body color EV2 without the metallic. Unless you have an original parked next to it, nobody will be able to tell the difference.
This!
Re: Where to get street hemi orange engine paint [Re: Cuda340] #2507559
06/12/18 04:00 PM
06/12/18 04:00 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
This!
That is what I do. Nason Ful-Thane single stage
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Where to get street hemi orange engine paint [Re: Cuda340] #2507566
06/12/18 04:25 PM
06/12/18 04:25 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What part of there are four shades of orange don't you all get?
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2507953
06/13/18 03:04 PM
06/13/18 03:04 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
No way I would go through all that work and use a rattle can.
Re: Where to get street hemi orange engine paint [Re: Aero426] #2507955
06/13/18 03:06 PM
06/13/18 03:06 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Apparently the OP IS willing to do the extra work. That's why he asked.
Re: Where to get street hemi orange engine paint [Re: 71birdJ68] #2508003
06/13/18 04:49 PM
06/13/18 04:49 PM
God's Country Maryland
GODSCOUNTRY340 Offline
VHT works great.
Re: Where to get street hemi orange engine paint [Re: moparmarks] #2508148
06/13/18 10:12 PM
06/13/18 10:12 PM
E
earlymopar Offline
earlymopar  Offline
E
Just beautiful MOPARMARKS. How is this for a someone to apply who is not experienced with a real spray gun? Do you need high quality regulator / filter / etc.?
- EM
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2508293
06/14/18 10:14 AM
06/14/18 10:14 AM
KY
65pacecar Offline
65pacecar  Offline
KY
http://www.hirschauto.com/ENGINE-ENAMEL/productinfo/EE-QUART/CHRY%20HEM%20O/
Bill Hirsch offers engine paint in Quart or Spray Can, his colors are pretty accurate.
Re: Where to get street hemi orange engine paint [Re: 65pacecar] #2509326
06/16/18 01:36 PM
06/16/18 01:36 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Mostly good info in your responses, NOW, should I prime the assembled engine, or just spray directly to cleaned metal?
Still looking for LM29H1B415501, '71 Demon 340
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2509335
06/16/18 02:15 PM
06/16/18 02:15 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Duplicolor engine enamels have always worked great for me. Even used their black wrinkle finish paint on my rocker covers. Came out awesome, perfect amount of wrinkle with heat lamps and heat gun. These were polished alum covers originally.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Where to get street hemi orange engine paint [Re: 6PKRTSE] #2509336
06/16/18 02:22 PM
06/16/18 02:22 PM
Don't prime unless you have a high heat primer. You don't want the primer to lift cause it will take the orange off with it. Clean the metal with Simoniz brake cleaner and spray the top coat.
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2509389
06/16/18 05:35 PM
06/16/18 05:35 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2509393
06/16/18 05:52 PM
06/16/18 05:52 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
No need for high heat paint. Automotive grade urethane will hold up fine and be more chemically resistant than rattle can stuff. Urethane may burn off an area of the intake if the heat crossover is not blocked. Not an issue for me as I always block the crossover. I even use bondo to fill small dents in the valve covers. . I put epoxy primer over everything. The stamped steel parts (valve covers, timing cover , oil pan) should be primed for sure.
Re: Where to get street hemi orange engine paint [Re: PAULS_340] #2509397
06/16/18 06:22 PM
06/16/18 06:22 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No primer required
Re: Where to get street hemi orange engine paint [Re: ScottSmith_Harms] #2509440
06/16/18 09:40 PM
06/16/18 09:40 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
No primer required
iagree
