Dana 60 Axle Removal #2509401
06/16/18 06:35 PM
06/16/18 06:35 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
So I am getting ready to pull the axles on a 1967 Dana 60 from my GTX. I have worked with many 8 3/4's but never a dana. I just want to pull the axles do the bearings and seals. I have heard the axles do not just pull out like an 8 3/4. Is this correct or do they just pull out? Thanks.
RS23L7 4-Speed
Re: Dana 60 Axle Removal [Re: Mopar_Mike] #2509409
06/16/18 06:49 PM
06/16/18 06:49 PM
Some one told you wrong about them tsk
They remove just like the 8 3/4, remove the five nuts on the bearing retainer and slide the axles out wrench
Make sure that the axle end play pins spacers don't fall out of the center block and get lost or bound up in the rear end when reassembling it scope
Re: Dana 60 Axle Removal [Re: Mopar_Mike] #2509412
06/16/18 06:52 PM
06/16/18 06:52 PM
Danville, NH
Danville, NH
Thanks Cab!
RS23L7 4-Speed
Re: Dana 60 Axle Removal [Re: Mopar_Mike] #2509732
06/17/18 09:15 PM
06/17/18 09:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If they don't slide out with very little pressure your housing may be bent twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Dana 60 Axle Removal [Re: fourgearsavoy] #2509888
06/18/18 10:38 AM
06/18/18 10:38 AM
an8sec70cuda Offline
Gus beer
iagree and/or the splines may have some twist. Look at em closely.
CHIP
'06 GMC 2500HD LBZ Duramax
