Re: BIGBLOCK PLUG WIRES
[Re: Magnumguy]
#2509387
06/16/18 05:19 PM
06/16/18 05:19 PM
RapidRobert
would it work to add some correct 90 deg boots (new or used) from another set?
[Re: RapidRobert]
#2509398
06/16/18 06:24 PM
06/16/18 06:24 PM
Posts: 10,647 S.E.Ohio
Magnumguy
S.E.Ohio
would it work to add some correct 90 deg boots (new or used) from another set? Tried that, but the wires were marginally long enough. I want wires that fit right.
[Re: Magnumguy]
#2509539
06/17/18 10:24 AM
06/17/18 10:24 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Firecore got every plug boots you need BUT the 135° ones when I ordered my second set, which are used on 8 and 1 plugs as far I recall?. ( I'm sure at least the 8th ). Since they didn't have the 135° degrees boots offered to install 90° but I told them didn't install any, because I could reinstall the ones I have on my running set
I sent them the CORRECT measures for 73 and lates setup, WHICH IS A DIFF LENGHT SET than pre 72s
[Re: Magnumguy]
#2509541
06/17/18 10:31 AM
06/17/18 10:31 AM
NachoRT74
Valencia, España
another option, get NOS ones, which uses to run into $50-80 rate on ebay. I got a set JUST to get the correct lenghts to make the Firecore250 ones.
( made a search and didn't float one at this moment... I know PN is something like 388xxxx )
[Re: Magnumguy]
#2511227
06/21/18 09:55 AM
06/21/18 09:55 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I prefer a set that I can cut and fit myself. Can't do that with Firecore since they only sell pre-made sets. Taylor or MSD for me. There is no magic in plug wires, or any ignition component for that matter, no matter what their best sales gimmick is. I've tried them on the dyno and at the track...as long as your wires are in good condition, they work fine.
[Re: an8sec70cuda]
#2511251
06/21/18 10:43 AM
06/21/18 10:43 AM
Posts: 3,916 usa
lewtot184
usa
I prefer a set that I can cut and fit myself. Can't do that with Firecore since they only sell pre-made sets. Taylor or MSD for me. There is no magic in plug wires, or any ignition component for that matter, no matter what their best sales gimmick is. I've tried them on the dyno and at the track...as long as your wires are in good condition, they work fine. sounds like me! I buy either taylor or msd bulk with boots and connectors and make it. people can change their oil so why is crimping a couple of connectors on a wire rocket science?
[Re: Magnumguy]
#2511254
06/21/18 11:08 AM
06/21/18 11:08 AM
NachoRT74
Valencia, España
Just found the measures I provided to customwires ( firecore ), measured per customwires specs, from center of terminal to center of terminal. Measured the NOS set I got to get the firecore set correctly done
Coil---9" 1-----22 1/4"----90º boot ( cilinder 2 ) 2-----25----90º boot ( cilinder 4 ) 3-----31 1/4"----90º boot ( cilinder 6 ) 4-----40 1/2"----135º boot ( cilinder 8 ) 5-----43 3/4" ---- 90º boot ( cilinder 1 ) 6-----48" 1/2" ---- 90º boot ( cilinder 3 ) 7-----55 3/4"----90º boot ( cilinder 5 ) 8-----56 1/2"----135º boot ( cilinder 7 )
This is to use the stock wire brackets ( which need to be trimmed a bit to accept 8 mm wires )
[Re: NachoRT74]
#2511303
06/21/18 01:20 PM
06/21/18 01:20 PM
Magnumguy
S.E.Ohio
This is to use the stock wire brackets ( which need to be trimmed a bit to accept 8 mm wires ) THANK YOU!!
[Re: Magnumguy]
#2511747
06/22/18 02:13 PM
06/22/18 02:13 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Sorry,hello, we are out of town, with very limited internet access, until next Wed. We can certainly get your order going when we return, thank you.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: RJS]
#2511865
06/22/18 06:53 PM
06/22/18 06:53 PM
NachoRT74
Valencia, España
Different year 400's used different lengths due to how they ran and different tabs on valve covers. I see later 400 wires on E-Bay often. Ron usually the diff is between pre72 and post73. I got the 73 and lates being my car 74, and those are the measurements I provided.
[Re: Magnumguy]
#2514759
06/29/18 02:15 AM
06/29/18 02:15 AM
sunroofgtx
Cleveland
Nacho, would you like to order? We are back? Thanks.. 866-973-9473.. Thanks..Thank you (Dilbert)!
