Sheet metal manifolds, who? #2509174
06/15/18 11:47 PM
06/15/18 11:47 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
My race program is leaning toward running a procharged & to keep things low, I'm looking for someone who can build a Max Wedge port B engine intake manifold with a throttle body flange on the front. Who do you suggest I ask that won't rape my wallet?
Re: Sheet metal manifolds, who? [Re: rebel] #2509189
06/16/18 12:43 AM
06/16/18 12:43 AM
Washington
madscientist Offline
Washington
Marcella.
Re: Sheet metal manifolds, who? [Re: rebel] #2509202
06/16/18 01:30 AM
06/16/18 01:30 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
There is nothing cheap about sheet metal intakes. On top of that, I have seen a lot of carnage with Gen # Hemi's, turbo's and backfires. TRE, Hogan, Marcela are all excellent companies.
[image][/image]
Re: Sheet metal manifolds, who? [Re: rebel] #2509227
06/16/18 05:54 AM
06/16/18 05:54 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
A member built a nice setup I dont know if he posts much but he may still have it for sale? It was on a procharged setup
thestigjr was his handle
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Sheet metal manifolds, who? [Re: madscientist] #2509250
06/16/18 10:03 AM
06/16/18 10:03 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Hemphill used to build a ton. Probably still does.
Re: Sheet metal manifolds, who? [Re: Hot 340] #2509290
06/16/18 12:17 PM
06/16/18 12:17 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
M&M in Indianapolis builds a nice piece at a fair price.
Re: Sheet metal manifolds, who? [Re: rebel] #2509302
06/16/18 12:43 PM
06/16/18 12:43 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
I went through a long process of selecting a builder for my sheet metal intake for my hemi. Spoke to many vendors and some very reputable and others not so much. What I learned was that if you want a custom intake find some one who has built exactly what you are looking for previously. Meaning they have the all the tooling and jigs to build a manifold that will fit perfectly. If not you are looking at sending block and heads to get it built correctly unless they happen to have the a block with same deck in house. In the end I selected Hogan to build my manifold. It was not cheap but in my opinion really good value.
76 Duster work in progress
Re: Sheet metal manifolds, who? [Re: rebel] #2509321
06/16/18 01:27 PM
06/16/18 01:27 PM
New York
polyspheric Offline
polyspheric  Offline
New York
My question: why is sheet metal better than fabricated from castings and structural shapes? Why is it aluminum instead of mild steel? Why metal at all?
Larry Widmer explained building a manifold from plastic and Super Glue 30 years ago... for Pro Stock.
Why not?
Vic Edelbrock didn't like it.
Boffin Emeritus
Re: Sheet metal manifolds, who? [Re: rebel] #2509376
06/16/18 04:33 PM
06/16/18 04:33 PM
A727Tflite Online content
A727Tflite  Online Content
- mild steel, needs plating or painting unless moly is used
- castings - someone needs to offer castings in the shape needed.
- structural shapes? Same as a casting - needs to be close what what is needed.
Items 2 and 3 would require more porting/finishing than sheet material. Plus it would weigh more, the racers enemy.
Plastic offers less protection from bursting in case of backfire.
Re: Sheet metal manifolds, who? [Re: rebel] #2509385
06/16/18 05:17 PM
06/16/18 05:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The better cast manifolds I've seen have far better internal shapes than fabricated.
Boffin Emeritus
Re: Sheet metal manifolds, who? [Re: rebel] #2509392
06/16/18 05:52 PM
06/16/18 05:52 PM
Mopar
Jason B Offline
Jason B  Offline
Mopar
TRE did a great job for our setup
1968 Cuda 440" Edelbrock Victor Head Small Block.
[img]https://board.moparts.org/ubbthreads/upload4/23859.png[/img]
Re: Sheet metal manifolds, who? [Re: rebel] #2509464
06/16/18 11:38 PM
06/16/18 11:38 PM
Can’t speak for all classes of drag racing but in Super Stock you will never again see a cast manifold on any competitive race hemi or six barrel Mopar Drag car in Super Stock.
Cast cross rams, rat roasters, factory six barrel, STR’s - extinct.
Any shape that can be cast can be fabricated.
It’s just my guess but I think besides a straight runner - the plenum is what most guys spend time flogging.
Re: Sheet metal manifolds, who? [Re: rebel] #2509480
06/17/18 12:59 AM
06/17/18 12:59 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Great pic Edge, are there any more pics like Edge's for us to look at & compare?
Re: Sheet metal manifolds, who? [Re: rebel] #2509717
06/17/18 07:50 PM
06/17/18 07:50 PM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
Marcella or HRE
Alan Jones
Re: Sheet metal manifolds, who? [Re: rebel] #2509976
06/18/18 01:28 PM
06/18/18 01:28 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
A friend of mine used CFE for his W8 heads and EFI intake for a twin turbo build. Does Wilson make sheet metal intakes?
I would think carbon fiber would be the best - strong, can be made into almost any shape, any taper runner, lightest, etc. Most expensive to make more than likely. Those F1 types can afford all of that.
I've thought about making some paired runners in a casting that could be CNC machined to match any port size for a SB or BB Mopar. Only reason for this is NSS rules where they want a cast manifold.
Floyd Lippencott IV
Re: Sheet metal manifolds, who? [Re: rebel] #2509986
06/18/18 01:54 PM
06/18/18 01:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
HRE FTW. I had a $4500 Marcella Intake. Needless to say it is now gone and HRE is currently building a proper intake for mine.
Re: Sheet metal manifolds, who? [Re: Al_Alguire] #2509997
06/18/18 02:17 PM
06/18/18 02:17 PM
PA
Harry's Taxi 2 Offline
PA
What didn't you like about the Marcella intake?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Sheet metal manifolds, who? [Re: rebel] #2510030
06/18/18 03:29 PM
06/18/18 03:29 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I've made a few intakes. You definitely need heads and block to get it right if anything is not standard. Aluminum moves around a lot when welding. The intake needs to start off bigger than needed, then finished to fit.
I am not soliciting work here. this kind of stuff is a hobby for me. The intake in these pics cost less than $140 including the home built throttle bodies. It would have been more expensive to buy a cast intake, not to mention that the ports were raised beyond any standard offering.
Re: Sheet metal manifolds, who? [Re: Al_Alguire] #2510800
06/20/18 01:39 PM
06/20/18 01:39 PM
CJD AUTOMOTIVE Offline
I'm curious too. First I heard about a problem with his intake design (has to be design, the fab is incredible).
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Sheet metal manifolds, who? [Re: rebel] #2510812
06/20/18 02:08 PM
06/20/18 02:08 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The intake was definitely very nice fit finish and workmanship. The design was 100% wrong for the application. Runners to long, plenum floor/port entry was wrong and plenum size was wrong. The intake had so much reversion on the dyno we gave up on it. When the top was removed it was fairly clear it was very unhappy there. Still made decent power but peaked well below where it should have. Those issues were noted by us and pointed out by others before we even ran it on the dyno, but we assumed it would work fairly well. In the end they were right and I am having a new one done that will be a completely different design.
