340 pushrods same as 318? #250905
03/11/09 05:48 PM
03/11/09 05:48 PM
central new york
pettyblue440 Offline OP
central new york
will 318 pushrods work in a 340? thanks
Re: 340 pushrods same as 318? [Re: pettyblue440] #250906
03/11/09 07:56 PM
03/11/09 07:56 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
yes and 360.
Re: 340 pushrods same as 318? [Re: MoparforLife] #250907
03/12/09 08:15 AM
03/12/09 08:15 AM
scratchnfotraction Offline
yes but not from a roller cam they are shorter
Re: 340 pushrods same as 318? [Re: scratchnfotraction] #250908
03/12/09 12:49 PM
03/12/09 12:49 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
Really??? by how much?
Re: 340 pushrods same as 318? [Re: 76Beeper] #250909
03/12/09 01:40 PM
03/12/09 01:40 PM
Upper Midwest
Upper Midwest
7.51 std length hydraulic. late 273 with hydraulic lifters, 318, 340, 360
6.78 pre magnum roller
6.925 roller magnum (92 up)
7.23 hyd. lifter with adjustable rockers
7.34 solid lifter (273)
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 340 pushrods same as 318? [Re: MoparforLife] #250910
03/12/09 02:52 PM
03/12/09 02:52 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
These guys are all correct, however don't take it for granted that your 318 pushrods are the correct length! I went through this with my 340, I installed the rocker arms/etc. and had all kinds of slop, the rocker arms were rattling terribly. Had all kinds of thoughts on what was wrong, it turned out that my 318 pushrods had worn (shorter) almost 1/16", enough to make a huge difference. They looked fine! I bought a new set, and they were snug, like they were suppose to be, and it runs nice and quiet.
Re: 340 pushrods same as 318? [Re: 4BBodies] #250911
03/12/09 02:56 PM
03/12/09 02:56 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
340-360 pushrods are longer than for a 318. I bought a new set that were shorter, they rattled around knocking clips out of the new lifters. Turned out that the parts store gave me some for a 318. They then ordered some for a 340 that were perfect.
Re: 340 pushrods same as 318? [Re: Dave Watt] #250912
03/12/09 03:08 PM
03/12/09 03:08 PM
I've never actually compared them but I would think that the 318/340/360 hyd cam ones would be the same. What dimention on the block/head/rocker arm setup is different between those 3 that would require different length pushrods? the only thing I could think of is if different cam lifts used different lengths to keep the geometry correct
Re: 340 pushrods same as 318? [Re: RapidRobert] #250913
03/12/09 03:39 PM
03/12/09 03:39 PM
IMO if it had the 3/8 pr and worn rockers then swap to 318 5/16 pr I could see them being a little shorter
with it apart and then bolt back down before start up some are gonna be loose and move around
they will pump up and force the rockers into each other
they mag pushrods are shorter and have diff rocker set up style (fulcrum) so they would be diff from pre mag roller lifter pushrods
some pre mag rollers have a 3/8 hollow pr and oil through roller lifter as well oils the old LA
rockers (oils both ways) early pre mag pushrods were 5 1/6 and solid
make sure you got the left and right offset in the right spot per cyl also
that could cause a problem
if using the fat pr in 318 heads check for clearance in the push rod hole of the head
later pre mag heads have a larger pr hole in them than early LA heads
I have never had a prob just swaping pr around,I roll them on glass to see if the are bent and run them
Re: 340 pushrods same as 318? [Re: Dave Watt] #250914
03/12/09 03:50 PM
03/12/09 03:50 PM
Upper Midwest
Upper Midwest
Somebody must have given you psuhrods for a SB roller then because All OEM small block pre-roller hydraulic push rods the same length whether it is the late 273 with hydraulic lifters or a 340 or 360.
Re: 340 pushrods same as 318? [Re: MoparforLife] #250915
03/12/09 04:06 PM
03/12/09 04:06 PM
Re: 340 pushrods same as 318? [Re: scratchnfotraction] #250916
03/12/09 04:19 PM
03/12/09 04:19 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Mopar part number for 318 340 are different in my 73 book 2899561 (318) and 2899567(340 and 360). Funny thing, until I checked I would have argued that they were the same. Of coarse then again a different part number doesn`t necessarily mean the length is different though.
Re: 340 pushrods same as 318? [Re: mopars4ever] #250917
03/12/09 06:16 PM
03/12/09 06:16 PM
Upper Midwest
Upper Midwest
Just did a Google and they both update to the same number in the after market books and they both have the same spec's. as to length and diameter. Chrysler Part numbers: 2899561, 2899567, 3780148, 4085291 all update to the same P rod.
Re: 340 pushrods same as 318? [Re: MoparforLife] #250918
03/12/09 08:34 PM
03/12/09 08:34 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Must have been a difference at one time or chrysler wouldn`t have bothered to have two part numbers in the same year.
Re: 340 pushrods same as 318? [Re: mopars4ever] #250919
03/12/09 08:40 PM
03/12/09 08:40 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I found no reference online that they supersede. Here is a NOS vendor listing for the two numbers.
PART NO DESCRIPTION YEAR QUANTITY PRICE
2899561 PUSHROD 1968 /273,318
2899567 PUSH ROD /8 CYL 1968-93
Re: 340 pushrods same as 318? [Re: mopars4ever] #250920
03/12/09 08:50 PM
03/12/09 08:50 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I wonder if it could have something to do with early 273's having solid lifters?
This is the land of the free because of the brave
Re: 340 pushrods same as 318? [Re: rbstroker] #250921
03/12/09 10:25 PM
03/12/09 10:25 PM
NY usa
540challenger Offline
NY usa
An aftermarket cam can cause the push rounds to be too short if it is a small base circle.
Re: 340 pushrods same as 318? [Re: 540challenger] #250922
03/12/09 11:24 PM
03/12/09 11:24 PM
dogdays Offline
dogdays  Offline
THE REAL ANSWER is this: On any high(er) performance engine one is better off building the engine, measuring the pushrod length and getting pushrods to match the correct length. There are way too many variables. Deck height, rocker type, cam grinder, lifter type and manufacturer, milled heads, head gasket thickness will all alter the distance between lifter and rocker arm.
R.
Re: 340 pushrods same as 318? [Re: pettyblue440] #250923
03/13/09 01:26 AM
03/13/09 01:26 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
It worked for me. I used one out of a '75 318 in my stock '73 340. I was told they are all the same length also. However when I checked them the 318 ones were a little shorter. I checked several. I could stand one of them between 2 straight 340 ones and it was noticably shorter. Wear? Production tolerances? I don't know but I decided to go ahead and try using a 318 one anyway and have driven it 3-4,xxx miles with no adverse effects I can tell.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: 340 pushrods same as 318? [Re: MOBodyman] #250924
03/13/09 08:21 AM
03/13/09 08:21 AM
the lifter will take up a small amount with the plunger and oil pressure
its non adjustable hyd and maintanes the lash with the oil pressure,installed the pr should have some preload to the plunger of the lifter
low oil and the lifters rattle and tap
but...to short is to short and should be measured like said
but I have rolled a many stock jy engines around in the yard swapping heads 1-2 pistons from block to block,used valves and no lapping of the seats and the like and have never had probs not measureing things...maybe just good luck..but hickabilly come to mind
some ran better than other and they all died in the mud truck eventuly..but mud and water was the killer
good luck with it
