Re: 70 E body oil pressure gauge not working
[Re: stumpy]
#2508963
06/15/18 03:33 PM
06/15/18 03:33 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Ground the sending wire and turn the key on. If the gauge rises then it most likely is a sender issue. Don't let the gauge peg out because you can burn it up. That didn't work, where should I look next? Electric is not my forte.lol
[Re: Sammy]
#2508968
06/15/18 03:54 PM
06/15/18 03:54 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Does your fuel gauge work ok?, both the OP and Fuel get power from the 5 V reg in the dash
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2509062
06/15/18 07:16 PM
06/15/18 07:16 PM
Sammy
Wind Gap,Pa.
Does your fuel gauge work ok?, both the OP and Fuel get power from the 5 V reg in the dash Fuel gauge and all other gauges work fine. I'm all out of ideas to fix it.
