What spare parts do you carry in your car ? #2508377
06/14/18 01:44 PM
06/14/18 01:44 PM
69x Offline OP
69x  Offline OP
Just wondering what parts are good to carry in our old cars in case of a breakdown, I guess it would be the most common parts that fail.
Re: What spare parts do you carry in your car ? [Re: 69x] #2508392
06/14/18 01:59 PM
06/14/18 01:59 PM
Guitar Jones Offline
I carry nothing in the old trucks. Ya gotta have faith!
Re: What spare parts do you carry in your car ? [Re: 69x] #2508416
06/14/18 02:44 PM
06/14/18 02:44 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I always have a spare ballast resistor with me.
Re: What spare parts do you carry in your car ? [Re: njmopar] #2508426
06/14/18 03:01 PM
06/14/18 03:01 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Me too!!!!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: What spare parts do you carry in your car ? [Re: 70gtx440dana] #2508428
06/14/18 03:03 PM
06/14/18 03:03 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Me too!!!!
Me three, along with a spare ignition control box.
Re: What spare parts do you carry in your car ? [Re: 6PakBee] #2508437
06/14/18 03:24 PM
06/14/18 03:24 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Me too!!!!
Install a hidden MSD and never worry about either again!
I carry a fire extinguisher, flat blade screwdriver and 1/2" wrench. The latter two for doing carb and timing adjustments.
'63 Dodge 330
11.19 @ 121 mph
Re: What spare parts do you carry in your car ? [Re: 69x] #2508452
06/14/18 03:47 PM
06/14/18 03:47 PM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
Ballast Resistor
Ignition Box
Voltage Regulator
A couple of quarts of oil
No longer taking $h!t from anyone!
Re: What spare parts do you carry in your car ? [Re: 69x] #2508466
06/14/18 04:38 PM
06/14/18 04:38 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Short trips, nothing. Long trips (like Buffalo NY to Mopar Nationals)? Well, spare rotor and cap, a couple ignition wires, duct tape, safety wire, basic tool box with screw drivers, sockets and wrenches. Usually all tools needed to change alternator, starter, tire, etc. I'll also carry a small coil of 12 ga stranded wire and electrical tape. For fluids, a quart or two of oil. Maybe a gallon of water. And a AAA card with long distance towing.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: What spare parts do you carry in your car ? [Re: 69x] #2508471
06/14/18 04:53 PM
06/14/18 04:53 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Ballast Resistor,
Set of Points in case the Petronix takes a dump
Coil
VR
Set of Alternator Brushes.
Simple tools
Re: What spare parts do you carry in your car ? [Re: 69x] #2508492
06/14/18 05:41 PM
06/14/18 05:41 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Ballast Resistor
ECU Box
Tire Plug Kit and Hand Pump (I don't carry spare tire)
Duct Tape
Cable Ties
Facts are stubborn things.
Re: What spare parts do you carry in your car ? [Re: 69x] #2508512
06/14/18 06:40 PM
06/14/18 06:40 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
All the above plus a fan and p/s belt.
Re: What spare parts do you carry in your car ? [Re: 69x] #2508516
06/14/18 06:47 PM
06/14/18 06:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
nothing. I have a cell phone and AAA if I need it but generally my older stuff works fine, because I have a very good mechanic.
Me.
Don't be the exception.
Re: What spare parts do you carry in your car ? [Re: Supercuda] #2508556
06/14/18 08:57 PM
06/14/18 08:57 PM
I don't even have AAA. laugh2 But I do have a cell phone.
Re: What spare parts do you carry in your car ? [Re: 69x] #2508558
06/14/18 09:11 PM
06/14/18 09:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, I do have a wife that thinks we need it, so we have it.
Re: What spare parts do you carry in your car ? [Re: RoadRunner] #2508563
06/14/18 09:41 PM
06/14/18 09:41 PM
IN
ahy Offline
ahy  Offline
IN
This is pretty much my list... tweaked a little for retrofit EFI. Only thing I changed was several gallons of water, brimmed hat and long sleeve shirt for a southern AZ desert crossing (I sunburn easily). Gladly I did not need any of it for an X country trip IL-CA and back.
Re: What spare parts do you carry in your car ? [Re: Guitar Jones] #2508569
06/14/18 09:51 PM
06/14/18 09:51 PM
BDW Offline
BDW  Offline
Same here, the financials just don't add up for AAA.
Way overpriced for the small benefits
Re: What spare parts do you carry in your car ? [Re: Supercuda] #2508572
06/14/18 10:00 PM
06/14/18 10:00 PM
jersey
Spaceman Spiff Offline
jersey
Me.
I have towing up to 150 miles one way, through hagerty.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: What spare parts do you carry in your car ? [Re: 69x] #2508660
06/15/18 12:46 AM
06/15/18 12:46 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Spare wife , so she can help push
Anyways how much extra is the Hagerty Plus or Premium plan and it only covers your collector car , that’s why I just keep the Hagerty Standard
AAA covers all my vehicles , drivers , hell one tow job basically covers the premium
They even towed my Snowmobile trailer for me once on a flatbed , that was Awesome especially considering where I was
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: What spare parts do you carry in your car ? [Re: 69x] #2508706
06/15/18 02:41 AM
06/15/18 02:41 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Cell phone and AAA. Last tow I needed was after 100 miles on the donut spare in my BMW. I was still 100 miles from home. I wasn't going to push that tire on the freeway, which was my option at that point. It was a Sunday afternoon into evening and a tire that couldn't just be bought anywhere, especially in Cool, CA or even Ripon where the tow originated.
Re: What spare parts do you carry in your car ? [Re: 69x] #2508715
06/15/18 03:22 AM
06/15/18 03:22 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
A phone, a $&@ or three, a small tool kit and some 'road service'...
All JIC...
Vintage 'road time' since 1994-have never had the need for any 'spare' parts...
