Bushing press kits for control arms #2505938
06/08/18 02:46 PM
06/08/18 02:46 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
Anyone have recommendations on a bushing press kit for upper and lower control arms?
Re: Bushing press kits for control arms [Re: 1970GTX] #2505973
06/08/18 04:05 PM
06/08/18 04:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A regular press works and is useful for more than just that.
Some all thread, pipe, nuts and washers will let you make your own as well.
http://www.crazysmopar.com/mycar_frontblog.html
http://www.fourbarrel.com/lcabushings.html
https://www.sportruck.com/howto/rebuildkit/5.htm
http://www.manciniracing.com/unfrsuprotok.html
Don't be the exception.
Re: Bushing press kits for control arms [Re: 1970GTX] #2508257
06/14/18 04:51 AM
06/14/18 04:51 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
when i did it a few years ago there was a youtube video on how to make you own the quick and easy way (you have to be able to weld)...
Re: Bushing press kits for control arms [Re: 1970GTX] #2508705
06/15/18 02:41 AM
06/15/18 02:41 AM
AndyF Offline
AndyF  Offline
Upper arms are easy, you can use bolts or sockets or just buy the correct tool.
The lower control arm can be a real PITA. I press out the inner shaft and then pry out the rubber. If the control arm has been used for awhile the rubber is usually destroyed anyway. The hard part is the outer shell. Welding a disc in there is one way to do it. Some guys use a really big tap and thread it out. My preferred method is to put it in a mill and use a big cutter to cut a groove in the shell.
Re: Bushing press kits for control arms [Re: 1970GTX] #2508709
06/15/18 02:44 AM
06/15/18 02:44 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
LCA bushing removal:
https://youtu.be/xYkQSI-2NRw
LCA bushing install:
https://youtu.be/f2Op00pO6Kw
Re: Bushing press kits for control arms [Re: 1970GTX] #2508710
06/15/18 02:45 AM
06/15/18 02:45 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
